Why does the Shift ARROW blink in my CX CLUSTER???
Old Jan 20, 2012 | 12:10 AM
jdmdomo's Avatar
Default Why does the Shift ARROW blink in my CX CLUSTER???
i just finish to swap my cx hatch with a gsr engine and the ''arrow'' blinks .. wtf .
Old Jan 20, 2012 | 05:17 AM
jdmcx's Avatar
Default Re: Why does the Shift ARROW blink in my CX CLUSTER???
what ecu are you using??
Old Jan 20, 2012 | 05:44 AM
fabioso's Avatar
I think somebody switched clusters from a federal vx. The shift light is supposed to tell you when to shift for max mpg.
Old Jan 20, 2012 | 09:28 AM
jjenkins's Avatar
Because it's a VX cluster, not a CX.
Old Jan 20, 2012 | 10:31 AM
CivicBlacksheep's Avatar
10 Year Member
The cx cluster comes with an upshift light.. You are using the wrong ECU
Old Jan 20, 2012 | 10:34 AM
jdmcx's Avatar
^^this
Old Jan 20, 2012 | 11:35 AM
94EG8's Avatar
Seagull Management
IIRC cruise and the upshift light both use the same pinout at the ECU, remember that no car had both, you got one or the other (or neither)
Old Jan 20, 2012 | 01:52 PM
angrysmileyface's Avatar
Damn, I want a Shift light...Oh wait, I want a low gas light too.
Old Jan 21, 2012 | 01:35 AM
jdmdomo's Avatar
im using a po5 ecu .. but actually i just change it to a p28 chipped ecu .
and they do the same thing .
also my car they dont wana start .
i put they key and i try to turn on the car . and i can ear the fuel pump working but . just dont wana start
i dont ear the starter do his job ., but if i put the foward and a screw driver on the starer works .
mmm???
and the check engine ligth its on all the way . they dont blink or trow some codes , its just there "ON"
also i dont iven wiring the car yet to vtec.
i just wana ear the motor on
i think its just something electrical or the distributor .?
Old Jan 21, 2012 | 05:42 AM
Former User's Avatar
Assuming that you don't have cruise control, unplugging connector D at the rear of the cluster should eliminate the shift arrow blinking problem.
Old Jan 21, 2012 | 05:49 AM
also my car they dont wana start . i dont ear the starter do his job ., but if i put the foward and a screw driver on the starer works .
Check whether the rubber stopper is missing:
Does the CEL remain on steady WITHOUT the service connector jumped?
Old Jan 21, 2012 | 12:31 PM
jdmdomo's Avatar
i was thinking that to .. let me check
Old Jan 23, 2012 | 10:46 AM
jdmdomo's Avatar
i got it man .. thanks .
drmix
16
Jun 1, 2010 02:35 AM
Hatch It
30
Jan 12, 2006 01:49 AM
boosted civic 2k6
12
Dec 3, 2005 08:05 AM
EK FLY
Jun 9, 2005 03:55 AM
Happyman
Mar 23, 2005 06:11 PM
