honda crx transmission question
Old Jan 20, 2012 | 03:26 AM
furikazashi's Avatar
Default honda crx transmission question
The synchronizers aare going out in my transmission and I'm unsure if I should get it rebuilt or buy a new one. The gears are still fine. I have a manual 1.6l SI engine its a 1989. Any ideas or links would be much appreciated. I work on cars a decent amount but never taken a transmission apart. Saw a rebuilt kit with the sleeve and rings of 80 and transmissions for 300-800 gauge by use
Old Jan 20, 2012 | 03:43 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: honda crx transmission question
Well I can tell you most of the time it's not syncros that go bad but rather the sleeve itself or the synchro rings. Tearing apart a SOHC is even easier than a DOHC trans (and those are pretty easy). The only way you will know exactly what is bad is to tear it apart and go from there. I have never seen the sleeves, rings, and synchros for $80 anywhere. My logic has always been if you rebuild it yourself (assuming you can do it right) you will have a mostly new transmission. If you buy a used one it could be in the same or worse shape as the one you already have.
There are quite a few write-ups and a couple books on how to do this, but the Internet should suffice.
Old Jan 20, 2012 | 04:44 AM
crvtectim's Avatar
That! ^
Old Jan 20, 2012 | 10:34 PM
EL Vap133's Avatar
Rebuild it, you can't get a new one these days.
Old Feb 11, 2012 | 08:52 PM
Thanks for the reply. I will be rebuilding it and changing all the synchronizers also
Elpecoso
Aug 11, 2016 05:39 PM
Paegelow
Apr 26, 2010 09:23 AM
1G_DX_to_2G_Si
Audio / Security / Video
Jun 11, 2005 08:40 PM
rice is nice
Jun 6, 2005 04:38 AM
hontegra
11
Oct 23, 2003 01:44 PM
