M10x1.25x130 bolts- Where can I get grade 8 or better?
The Grumpiest
McMaster-Carr only has this in a 120mm length. Will I have to get these made? They're for the inner LCAs.
The Grumpiest
Found a socket head.
http://www.ballerbolts.com/titanium-...-25x130mm.html
They have them here as well. Couple dollars cheaper in titanium.
The Grumpiest
The Grumpiest
So I've learned that unless you can make these or get someone to make these you cannot get this size in stainless steel longer than 120mm. You can only get them in titanium and they are SPENDY. Average cost is $30 for ONE!
The Grumpiest
Yup! I have a little minor subframe damage on the right side from the previous owner (that I didn't know about when I bought the car) and am also running an ASR brace (to support the damage). When I took it off to install new LCAs I realized that there never really were enough threads actually securing that whole assembly in the first place. I think it took me less than 3 turns of a ratchet and it loosened right up. Scared the crap outta me so I went off in search of longer ones. The ASR uses 120mm bolts and no one makes longer ones (off the shelf) in steel so I have to go this route for piece of mind
I know of a bolt manufacture that I had to get bolts from a couple weeks ago for my engine stand ill see if they have that siize or I can get u the number
The Grumpiest
Ordered a pair of M10x1.25.135mm in titanium from Ballerbolts. Damn it was pricey. I'll post back when they get here and see how fast they ship. They also have some bolt kits for Hondas in all titanium. Truly baller stuff.
The Grumpiest
Of course. Because I'm stupid and only remembered to do it AFTER I placed that order!
Smith Fasteners
M10 1.25 x 130 8.8 hex bolt is $4.15 each
Smith Fasteners
But they're titanium.
