gsr and itr cams
Im building an lsv with b18b bottom end and gsr head. Was gonna but itr cams but they're very hard to find and expensive, i head of people using the gsr intake cam and itr exhasut cam. is this a possibilty and if so would you recommend it or just stick with both gsr cams. I will be buying itr valvetrain also
ITR intake GSR exhaust is much more common than ITR exh GSR int
I'm surprised you are finding ITR cams to be expensive. Used ones should be fairly cheap. Of course you can also get BloxAs pretty cheap and those are good cams.
going rate for itr cams in clean condition is $300-350
not always easy to find either.
my advice if you just HAVE to stay NA is to use gsr or itr cams if you're making a driver. if you're after that extra 20-30whp from an "na build" just buy the blox c's, some 310cc injectors and a big *** header. set the compression around 11:5-1 and have a 200whp car
the drawbacks are
1. blox c's are more aggressive and you won't get 100k+ for mileage
2. the bottom end will go to 9500rpm which again means no 100k mile motor
3. slight decrease in mpg
what makes no sense to me with the B series are the "almost builds" skunk tuner 1s, blox A's etc.. you'll wind up spending just as much as using the C's and have 15whp or so less
the oem honda stuff is so reliable that i personally don't sway from it on the top end. there's a little more flex in the bottom end, mostly for forced induction but the oem top ends are just wonderful for a long life.
then again the way i see the b series is pretty simple: leave it stock or boost it. as for why?
* NA build = $3000 gains you 20whp
* top notch turbo setup costs $4000 gains you 120whp+
seems like an easy choice
the drawbacks are
When a person would want stage 1 cams:
- They want "drop in" cams for a basic from-scratch build like an LS vtec. These have all the advantages you ascribe to OEM cams and none of the disadvantages of pro-level cams. Find one example of a person whose had the life of their head reduced by using S2S1 vs. OEM.
- They want to add cams to a build with low (<11:1) compression, either because they don't want to mess with higher compression or because they are adding cams to a stock engine and don't want to do bottom end work.
Since a lot of people fall into those categories, I see stage1 cams as being a good option for many.
That said if I were building an engine from scratch I would go for 11.5:1 and S2P1s. But I can't see any reason to chose ITR over BloxA or S2S1 other than possible price.
That's how some DSM guys do it too. 272 intake 264 exhaust.
I didn't think people were still having trouble with Skunk2 cams. But there have been a couple Blox snaps on the forum.
In any case OP is planning on 12.5:1 comp so speculation about cam failure may be a moot point. In fact at that compression maybe s2s2 or s2p1 would make more sense.
