Inner tie rod question
I am currently rebuilding my hatch from the ground up. I am in the process of reassembling the steering rack. I had purchased Moog both inner & outter tie rod ends. My question is about the design of the inner tie rod. Upon opening the inner tie rods I discovered that the design of the 2 are completely different. One looked exactly like the old ones. The other was completely different. See pics below.
The factory piece
The odd Moog replacement
Notice the ball pivots are on different sides.
Originally I just figured the wrong part was in the correct box, but after verifying the design of the part from other part stores. I realized that Moog must have changed their design.
To get to my point... Should I return the Moog peice & get an alternate brand (Beck Arnley) or should I just run the new design on one side & the old on the other?
The factory piece
Moog is actually one of the better aftermarket parts manufacturers, I would trust Moog over Beck Arnley, Milestar, OE Spectrum etc etc... Unless you go through Honda unfortunately you won't get the exact same part. Aftermarket parts manufacturers' products don't look exactly like a honda part. I can assure you though they're the same part
I also agree with the fact that moog makes quality parts. That's why I ordered them in the first place. However, I received 2 different designs from moog. One looks exactly like the replacement in the 1st pic & the other looks like the 2nd pic. My question is will it matter if I run the moog replacement that looks like the oem peice on one side & the moog replacement that has different design (as pictured) on the other side.
Is it possible to just get two of the new design?
I don't see the harm in having the two different designs on the inner tie rods but it would be comforting to know you have two of the same down there anyway.
I just rebuilt my steering rack as well with OEM parts and a Quaife Rack and pinion.
and +1 for Moog.
and +1 for Moog.
and +1 for Moog.
and +1 for Moog.
How do you like the Quaife rack? I debated on adding this, but felt the bang for the buck wasn't in its favor. Did you notice a big difference from stock?
Haven't driven the car yet, but messing with the wheel, it seems to be pretty damn quick.
http://www.tamparacing.com/forums/pr...h-build-6.html
OEM pinion on the top.
CleanHatch
Oct 23, 2005 02:13 PM
