Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
04 Accord 2.4L knocking manual trans.
Old Jan 18, 2012 | 05:10 PM
truebluefoo's Avatar
Default 04 Accord 2.4L knocking manual trans.
My 04 accord has been and continues to knock or misfire at a low RPM (15-1900) in 1st and 2nd gear. any gears or RPMs outside that range are safe from any noise, but maybe it's there and I cannot hear it. My oil level is good, and if I remember correctly no high octane or gas additive fuel has helped my problem. Cold or Hot weather I am still able to hear the noise. I do believe Hot weather is less noticeable then a cold engine, but it's still there. New spark plugs only about a year ago. I run 5W30. Any suggestions? I've heard of Rod Knock, but I've also heard it gets louder with an increase in RPM. Perhaps a valve adjustment I'm hoping? Any ideas from a learned mechanic? Thanks
Old Jan 18, 2012 | 05:15 PM
MSchu's Avatar
My Name is Nobody
Default Re: 04 Accord 2.4L knocking manual trans.
Originally Posted by truebluefoo
Any suggestions?
Thanks
Yeah... stop forcing your engine to work harder than is necessary and learn how to operate a automobile correctly.
Old Jan 20, 2012 | 03:45 PM
lol are u serious.....im pretty sure im a good driver.....it does it in first gear...how low do you want me to go....im not lugging the engine...it does it when im fully in gear..flat road....even at 2000 rpm....now can i get a new diagnosis.....if im not operating correctly....please enlighten me on what im doing wrong
Old Jan 22, 2012 | 08:43 PM
dellon14's Avatar
you probably need a valve adjustment. had the same issue with mine
Old Jan 27, 2012 | 08:11 PM
D-JET's Avatar
try making a video
Dan_Honda
11
Jan 10, 2022 06:24 AM
kenpoed
Dec 20, 2014 06:31 AM
curtie94
Dec 28, 2011 05:28 PM
stewart57
Dec 29, 2010 04:51 PM
servion
May 7, 2002 02:07 AM
