0bd0 to 0bd1 rywire jumper harness
Old Jan 18, 2012 | 11:12 AM
ef9allday's Avatar
Default 0bd0 to 0bd1 rywire jumper harness
Where does the extra wires that come with it wire to? ?
Old Jan 18, 2012 | 12:17 PM
crx_si-r's Avatar
Default Re: 0bd0 to 0bd1 rywire jumper harness
Look at the instructions
Old Jan 18, 2012 | 12:52 PM
Spug's Avatar
http://www.rywire.com/catalog/images...0to1jumper.gif
Old Jan 18, 2012 | 01:28 PM
jdmef69's Avatar
For vtec and second o2 sensor I believe
Old Jan 18, 2012 | 01:50 PM
ef9allday's Avatar
So those extra wires are only if u have v tec?
Old Jan 18, 2012 | 01:53 PM
ef9allday's Avatar
Also the distibutor jumper does not plug into my si distributor. Does that mean i need a obd1 distributor or i wont need it
Old Jan 18, 2012 | 02:12 PM
crx_si-r's Avatar
If it doesn't plug in the. U have a dx model. Which means that the ecu jumper will not work until you make the needed modifications on your stock ecu plugs from DPFI to mpfi
Old Jan 18, 2012 | 03:00 PM
KINGVEM^^ED6's Avatar
Man seems like you didn't research before you spent all that money
Old Jan 18, 2012 | 04:25 PM
jdmef69's Avatar
You need to do some easy mods to your stock ecu plugs. Add and cut a few wires change dizzy plug to mpfi
Old Jan 18, 2012 | 07:45 PM
AintGotNoSol's Avatar
btw, yes, you need an obd1 distributor. If you bought jumper plugs to go from obd0 to obd1, and got the distributor jumpers....
man I don't even understand why you would ask that. basically what you said is... "i got the jumpers to connect an obd1 distributor to my obd0 harness, but the obd0 distributor won't plug into the jumpers. do i need an obd1 distributor?"
What exactly are you doing to this car? Are you swapping in an obd1 engine? or are you trying to do an MPFI swap? cause that's totally different, and the obd1 jumper kit will not do that for you.
Old Jan 23, 2012 | 08:51 AM
ef9allday's Avatar
Ok so this is wat it is....i have a d16z6 inside but i was running it with my stock intake mani...therefore running dpfi....i got all the things i needed to run mpfi...si distributor,injector resistor box,z6intake mani n fuel rail and ecu....did all the wiring for the swap...n was running it for a while....then my ecu went out...i had the hardest time finding a ecu so i herd that i could switch over from obd to obd1 so i bought a p28 ecu.....but i just recently got another 92-95 distributor n the distributor jumper now plugs in. So sorry if i asked stupid questions lol
Pancho2193
Mar 4, 2013 05:33 AM
ef602
Aug 5, 2009 08:46 PM
JokerX-1.6T
Jun 10, 2008 07:10 PM
mahatma
Jun 9, 2006 04:14 AM
JohnnyB70
Dec 2, 2004 05:56 AM
