No start issue. Searched and tried everything.
Old Jan 18, 2012 | 10:27 AM
v0.cakes's Avatar
Default No start issue. Searched and tried everything.
Hello Honda-Tech members,
I understand this is a very repetitive question, however i've tried everything to no avail.
Background story:
Car is a 1996 Civic DX hatch, with a b16 swap. car started and ran perfectly fine for more than 10k miles. One morning went to the store, left the car for no more than 10 minutes. Came back and car wouldn't start.
Things I have done:
-Battery is good. All dash lights work. Fuel pump primes. No CEL.
-Tried two different starters.
-Tried another ECU.
-Changed the main relay with a known good one (bought a new one from honda)
-I did a bypass jump to the starter, and she started right up.
So I'm thinking this is a wiring issue, however I'm unsure where to start. Any insight, on what I can do. Any help is appreciated. Car hasn't been running for a month now. I have a multimeter, so if any numbers are needed, I'll be glad to do what I can.
Edit/ more info:
when I turn the key to on, main relay does its thing click-click. Cel stays on for about 3 seconds. fuel pump primes. then when I turn the key to III, nothing happens. car doesn't turn over or anything.
Thanks
Old Jan 18, 2012 | 10:28 AM
Dc4LsTeG's Avatar
EK9
Default Re: No start issue. Searched and tried everything.
Grounds good?
Old Jan 18, 2012 | 10:48 AM
daze-delsol's Avatar
also how old was the distributor and have u checked if u get spark? i just had the same thing on my 00 civic with a b18c5 and couldnt afford a new dist. for a type r so went msd started rite up new rotor cap and plug and its been running good since then
Old Jan 18, 2012 | 10:53 AM
v0.cakes's Avatar
Originally Posted by Dc4LsTeG
Grounds good?
all grounds are good. sanded and cleaned them up.
not sure how old the distributor is. I bought the car with the swap from a friend. motor has about 87k on it.
i don't get any spark. when I turn the key to run nothing happens. any ideas?
Old Jan 18, 2012 | 11:11 AM
well u wont know from that if u have spark or not when engine trying to turn over hmmmmm my mexican way of cheking is taking out one of your wires put a screw driver in it and put it close to one of the 10m for metal contact and have someone try to turn the car on if u have spark u will see it there if u dont then u can also see cause nothing will happen
Old Jan 18, 2012 | 11:17 AM
Dc4LsTeG's Avatar
EK9
So no power at all when you turn the key?or the car just doesn't crank?
Old Jan 18, 2012 | 11:18 AM
Former User's Avatar
Manual transmission? Check the rubber/plastic stopper that presses on the safety switch.
Old Jan 18, 2012 | 11:26 AM
DirtyDA9's Avatar
^^ This x2.
Old Jan 20, 2012 | 09:55 AM
v0.cakes's Avatar
finally got time off work today, so took a look at the safety switch. ended up going to Honda to buy a new plastic stopper. What do you know, that was the culprit. She started up right after. (I also replaced the brake switch stopper just in case that one goes out)
Thanks for the help RonJ@HT, as well as everyone else who had input.
Have a happy friday everyone!
MrConti
Jul 28, 2017 02:03 AM
courtham916
Apr 11, 2014 06:57 PM
SiRkid
Aug 5, 2009 04:42 PM
hotinteggy
Oct 22, 2007 04:44 PM
91d15bvtec
Jun 28, 2005 01:42 PM
