This Main Relay Good or Bad?
Old Jan 18, 2012 | 08:24 AM
JusAccord's Avatar
Default This Main Relay Good or Bad?
Does this Main relay look good or bad, wha you think? i see some little rust spots around but i dont know if its that bad to cause the starting problems im having..
should i buy a new one?
Old Jan 18, 2012 | 08:36 AM
roller3804's Avatar
Default Re: This Main Relay Good or Bad?
Sorry but it is really hard to tell with those pictures. Look for any cracks in the solder.. You could try and just remelt all the pins and see if it cures the problem..I would just buy a new one if you aren't sure what you are looking for..
Old Jan 18, 2012 | 08:42 AM
mherkamp's Avatar
Thats not rust, thats the solder flux left over from when the board was made, not an issue. I would push/pull/wiggle gently on each connection and resolder any that are loose or appear to move. You'l know if you have a bad one.
GL
Mike
Old Jan 18, 2012 | 09:16 AM
JusAccord's Avatar
GL
Mike
ok well the solder flux thing looks like it got everywhere on the board alil bit, or wha about that
Old Jan 18, 2012 | 09:19 AM
mherkamp's Avatar
They also encapsulate the boards with an epoxy product so that the connections and components will be less suseptible to water damage. That is probably what you are seeing, again not a problem.
Old Jan 18, 2012 | 09:23 AM
JusAccord's Avatar
ok so then im good, ill do that push/wiggle wit the connectors and see wha happens, if anything ill jus get a new one jus to be sure, i check my fuel pressure, fuel is comin through, so im good on that, today ima get the battery fully charged
Old Jan 18, 2012 | 01:21 PM
Apex1972's Avatar
I would just do like the other guy said, hit all the points with a hot soldering iron to be sure. If you have a friend with a mid 90s honda, try it out on their car to see if it gives the same symptoms it does on yours. good luck
Old Jan 19, 2012 | 05:12 PM
JusAccord's Avatar
ok, ill see if i can make that happened and can i try it in a 95 honda civic?
Old Jan 19, 2012 | 08:54 PM
Apex1972's Avatar
sure.
Old Jan 22, 2012 | 11:23 AM
scarface1346's Avatar
what are your starting symptoms? i just posted a new thread on my starting issue maybe we got same thing going on and can share findings or fix.
Old Jan 22, 2012 | 12:59 PM
JusAccord's Avatar
my car is jus cranking up but wont turn all the way over, im really close tho, i jus got my starter checked today, its good so its not the starter, now im gonna work on the fuel, see if fuel is even goin through
Old Jan 23, 2012 | 04:26 AM
mherkamp's Avatar
Sounds like battery to me, have you checked its voltage? Take it to autozone or wherever and have them load test it (its free). Could have a dead cell, show close to good voltage and then drop severely during cranking.
Old Jan 23, 2012 | 04:34 AM
97ludedude's Avatar
X2. if it was the main relay it would spin over fine just wouldn't actually crank. If it is trying to spin over but then stops then it is either a weak battery, bad battery, cables loose or corroded, or defective starter. Have you tried to jump the car off?
Old Jan 25, 2012 | 04:43 AM
JusAccord's Avatar
i bought the righ battery and tryed it wit the new battery, now the engine is very close to starting all the way, something else is up, today ima mess wit the fuses and fuel system
i got the starter check at autozone, they said its good
Old Jan 25, 2012 | 03:00 PM
holmesnmanny's Avatar
You can get these things for like 25 bucks at rockauto. You just have to wade through different categories and find one cheap. I got mines for 30 out the door with a coupon code.
88_hatch_ls
May 9, 2011 08:36 AM
8dxhatchy8
35
Feb 16, 2009 06:49 PM
whiteformula98
Aug 3, 2008 08:53 PM
scorpiontank
Jul 20, 2007 01:21 PM
88da3
May 31, 2005 09:26 PM
