Odo and trip not working correctly
Old Jan 18, 2012 | 07:50 AM
mrspeedy69's Avatar
Default Odo and trip not working correctly
I've searched and found a few things but not exactly what I'm looking for. I bought a used set of guage clusters for my del sol. Everything works on it except the odometer and trip meter and here is what it does.
If I hit the trip reset button a few times it starts working for a little bit. Both will count up and then just stop randomly. Once I went half a mile, next was 3miles, then 1 mile. So I'm not real sure whats going on.
My next question is, if the odometer and trip are just broken is there a way to swap just that part from my old cluster into the one I bought?
Old Jan 18, 2012 | 01:01 PM
Marvin1985's Avatar
Default Re: Odo and trip not working correctly
You test your VSS? Start there
Old Jan 18, 2012 | 03:32 PM
mrspeedy69's Avatar
It's working fine. The odometer and trip work just fine with the old gauges put back in.
Old Jan 18, 2012 | 04:16 PM
dwkt's Avatar
need new cluster
Old Jan 18, 2012 | 04:49 PM
Former User's Avatar
Replace the speedometer unit.
Old Jan 18, 2012 | 05:02 PM
mrspeedy69's Avatar
That was one of my questions. Can you just replace the odometer part or do you have to replace the entire cluster?
Old Jan 18, 2012 | 06:00 PM
mrspeedy69's Avatar
Never mind I figured it out. Thanks for the replies everyone.
Old Sep 15, 2024 | 03:53 PM
Plingjago's Avatar
What did you do? Having this exact problem.
TYL3R
Jun 6, 2008 10:02 AM
funtak
Jul 18, 2007 03:31 PM
civiccpedx
May 18, 2007 06:56 PM
5thgencivicr
Jul 7, 2005 05:35 PM
truthaccord
Mar 30, 2004 03:22 PM
