Budget Boost Built GSR Block Built B16 Head
Call/Text Joel 909-728-9967
$1800 SHIPPED OBO GSR BUILT for BOOST BOTTOM END Good for 450whp Beyond that I have no physical proof, but w/ A DAMN GOOD TUNE I SUPPOSE.
IT WILL BE FULLY ASSEMBLED shortly
- B18C1 0 Miles on setup
- New formz block guard ( Custom Machined and chamfered extra coolant ports )
- Full floating LS NPR Low Comp Pistons ( 81.5mm Custom C-Clip Groove by RS Machines )
- New Wrist pins w/ JE c-lips
- NPR Piston rings 81.5mm
- Scat H Beam Rods w/ ARP Rod Bolts
- ACL main & rod Bearings
- New OEM ITR oil Pump
- New OEM ITR water pump
- New T-belt
- New Oil Pick up
- New oil pan gasket
- Hot Tanked
- Decked
- Bored 81.5mm
- ARP Headstuds
- B18C1 Crank Balanced and Polished
ILL WORK ON BETTER PICS!!!!!!!!!!!!!!
$1500 Shipped OBO EVERYTHING YOU SEE HERE IS ALL FRESH 0 MILES NO START UPS!!
Built B16 Head 0 miles
- Port by KG
- Full port & polish
- 5 angle valve job
- omni dual valvesprings
- omni valves & retainers
- bronze valve guides
- blox stage 2/hsl cams ( lobes are same as skunk2 H8's )
- aem black cam gears 5bolt new
- hot tanked & magnafluxed
- new seals
- oem wrinkle valve cover
- thermal IM gasket
- password jdm cam seal triple-o
- brand new oem b16 vtec solenoid ( subtract $250 if you do not want this )
- New T-belt
- New Oil Pick up
- Hot Tanked
- Decked
- Bored 81.5mm
- ARP Headstuds
- Port by KG
- 5 angle valve job
- new seals
- thermal IM gasket
I'll get some tomorrow of the block as it sits now, busy day at work, but I'll try and remember. I have some pics of it before that I'll post shortly.
Damn, that's some good HP!!! Thanks for that info. I appreciate it.
Beans90crx
Mid-Atlantic (Sales)
14
Oct 3, 2012 09:15 AM
