97 civic - power with key off, no power with key on
Old Jan 17, 2012 | 06:35 PM
DroppedEJ6's Avatar
Icon2 97 civic - power with key off, no power with key on
I have a 97 civic i bought the car with a LS in OBD-1 Come To find out the motor in the car was blown up....
I built a Poor Mans Type R swapped it in....
but not to sure what is going on
the ls started up car acted normal now
no key in the ignition my radiator fan, check engine light, heater blower but when i put the key In the ignition and turn it on to accessory i lose all power , only light that comes on is the seat belt light WTF.... then i go to start it and the fans and check engine light comes back on but doesnt even attempt to start or turn the starter ???
any one got any ideas ??
Old Jan 17, 2012 | 08:02 PM
Former User's Avatar
Default Re: 97 civic key problem
Test the ignition switch.
Old Jan 18, 2012 | 05:52 AM
DroppedEJ6's Avatar
Ok ill do that today
Old Jan 18, 2012 | 05:57 AM
There should be a testing diagram in the FAQs sticky.
Old Jan 18, 2012 | 10:35 AM
DroppedEJ6's Avatar
Looked threw everything but it all looks fine , now a new question when i unhooked my starter everything goes off and returns to normal except when i turn the key forword i dont have an engine light at all and my fan doesnt come on ??
Old Jan 19, 2012 | 02:32 PM
DroppedEJ6's Avatar
Figured it out thanks for some pointers
Old Jan 19, 2012 | 02:41 PM
mitchie55's Avatar
What was the cause?
Old Jan 20, 2012 | 03:28 AM
DroppedEJ6's Avatar
My ecu wasnt grounded properly
Old Jan 20, 2012 | 04:39 AM
Can you give more details?
Old Jan 20, 2012 | 05:08 AM
DroppedEJ6's Avatar
Default Re: 97 civic - power with key off, no power with key on
well the double loop ground wasn't making proper connection to the thermostat because my wire was broken before loop so there for i dont know how it was powering the ECU to tell my check engine light and fan to run but i fix the wire and ever returned to normal
maxpaddy
Honda Civic (2001 - 2005)
Sep 24, 2018 06:15 AM
ThatRHDstatus
May 15, 2016 03:52 PM
Hondacrxblk
Dec 23, 2008 01:14 PM
xaine
Aug 28, 2008 07:38 PM
travis
Dec 8, 2003 11:56 AM
