timing belt problem
when i trun my crank counter clock wise it just loosens the bolt! and when i turn it clock wise the belt just loosens and wont turn my cam gears! im getting so upset and pissed about it! and for me to be able to do my valve adjustment i have to turn it clockwise but i can if the belt loosens and wont turn my cam gears!
can someone help me out before i pitch this damn thing!
yeah only if i could afford an air compressor and an impact gun! i need to turn the crank so that my cams turn so i can do my valve adjustment! u know like 1,4,3,2
my cam gears wont line up correctly and my valves are pushed down on the intake side (idk if this is normal or not but it happened when i installed my cams).. its a headache right now!
ive been lost dude.. i gave up and called it a day! im just gonna send it to a shop to get the stuff done sense i dont have the right equipment to do everything!
is it okay if my valves are pushed down by the camshaft? all i did was install camsgafts correctly and then torque all the necessary parts, then i looked in the intake manifold area where i can see the valve, and its pushed down by the lobes! will this affect anything?
You can torque the crank pulley bolt with a chain whench and a 1/2 drive breaker bar you don't need an impact gun..but before you start the car make sure you use a torque wrench on the bolt
yeah the timing part is what im worried about the most.. the rest i can do myself because ive probably did 3 months of research before i even got this engine! but i do know the ls/vtec engine timing will always be off slightly so i know that part, and which it is off slightly..
ls/vtec:
b16a head
brian crower dual valve springs and retainers
stage2 skunk2 proseries camshafts
blox high compression flat face valves
pr3 cam gears
b18a1 bottom:
p30 pistons shotpenned onto ls rods
b20crank (same as b18a1)
stock bore 81mm
b16a head
pr3 cam gears
b18a1 bottom:
stock bore 81mm
yeah i have aftermarket ones but they are still on my old engine and its too cold out to pull them off.. but ill do that here soon! and the pr3 ones i tried to parallel the best i can, but when they are the up arrows are crooked!
