Is Mobil1 Synth oil good for LS Tranny in a GS-R?
As states. Had my ITR tranny in my GS-R blow apart. They are replcing the tranny w. an LS tranny and All i have is Mobil1 Syhthetic 10w30. Shouls that be ok for the tranny?
Like mentioned above, get the Honda tranny fluid from the dealer, its pretty cheap and is the best. I even get my oil filters from there as they are only a little under 3 dollars
LOL any one here EVER looked at the Chem code of honda MTF and 10W-40 Motor oil????
There the SAME honda doesn't even put in an additive to make it seem like there giving you a better oil.
besides the Amsoil gives a smother shift to the tranny and amsoil will back you up if there oil is the cuase of a failure in the tranny.(atlest thay did when i got some the last time)
+1. Honda MTF smells like cat ****. I can't stand it. There is no way Honda MTF is the same as a 10-40 conventional oil. Maybe they just added some cat **** and called it a day, but there is something else in there.
maybe they changed it in the last few years i havn't gotten any sence 1996 and at that time it looked and smelled just like motor oil.
On a metel on metel test normal oil dosent creat as good of a film as honda mtf.. I have see it in person and mtf isnt just motor oil... Have it tested next to normal motor oil..
MObil one is junk as well... Once again do a metel on metel test its worst then normal Castrol gtx .. Even royal purple is bad it sulfer plates very bad.. Bradpenn all the way
sL3epy187
Transmission & Drivetrain
Sep 4, 2008 09:38 AM
