Greddy Timing Belt Installed In Wrong Direction on N/A H22
Old Jan 17, 2012 | 01:26 PM
Speedfiend97LX's Avatar
Default Greddy Timing Belt Installed In Wrong Direction on N/A H22
So in an epic dumbass move I somehow installed my Greddy timing belt opposite of the directional arrows. The guy that was helping me was in a huge hurry and I never saw the arrows until I recently had a faint squealing sound coming from the timing belt area. I pulled the covers off but nothing looked out of place. Then I noticed the arrows and thought well they're pointing the opposite of the direction the motor turns. I've never done a timing belt before and didn't know the direction mattered. I just had the car tuned a month ago and it ran fine but lately it was making that noise and the idle was really low when I would come to a stop, almost stalling out but it never did. I've read that bc it is probably stretched the opposite direction that I shouldn't reuse it. My question is, is the direction of the belt a big deal? If so I'll replace it but it's gonna be a pita in my 97 Accord but I'm sure I can do it. What do you guys think? By the way I have a H22a with S2 pro1 cams, valvetrain and so on. Did 220 whp when I had it tuned a month ago. Please let me know what you guys think. Thanks.
Old Jan 18, 2012 | 01:15 PM
Default Re: Greddy Timing Belt Installed In Wrong Direction on N/A H22
Anyone?
Old Jan 18, 2012 | 02:57 PM
phootbag's Avatar
I've never seen a directional timing belt.
Old Jan 18, 2012 | 03:10 PM
Then what are the arrows for? It's gotta be directional right?
Old Jan 18, 2012 | 04:50 PM
Fred Demara's Avatar
are they pointing to a timing mark on the belt? the easiest/fastest way to determine if you're in trouble is a compression test.
keep us posted, and good luck
Old Jan 18, 2012 | 05:11 PM
Hawkze_2.3's Avatar
How can a timing belt be directional...what's the difference?
Old Jan 18, 2012 | 05:37 PM
v4lu3s's Avatar
RTFM
i would be contacting greddy if i was concerned.
Old Jan 18, 2012 | 05:40 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
T-belts are not directional.
Old Jan 18, 2012 | 06:41 PM
The arrows run long ways with the length of the belt not side to side. So I can't figure out what else they would be for. There are 5 arrows and they run side by side. Here's a pic I found and mine looks exactly like this one.
http://www.greddy.com/products/engine/timing-belts/
Old Jan 18, 2012 | 06:52 PM
MAD_MIKE's Avatar
MM Gruppe B
I wonder if it has an 'aqua tread' pattern on the underside of the belt
The only time you would pay attention to those arrows is if you had to remove/reinstall the belt and didn't take note of what orientation the belt was in.
Old Jan 18, 2012 | 09:27 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
That belt should also have timing marks on it. The arrows are to show you which way the belt faces so that the marks on the belt line up with the marks on the car. They may not line up correctly if installed backwards. I guess in a sense that could make it directional,but there is no harm in ignoring the marks on the belt, they are there to make installation easier.
Old Jan 18, 2012 | 09:29 PM
holmesnmanny's Avatar
Yeah, the only time you would need to worry about directional marks is if the belt was already installed and was taken off. When you then put it back on, you would want it to be back in the same direction.
Old Jan 19, 2012 | 01:14 PM
So I called Greddy today and the guy I talked to said they are directional arrows and the belt is constructed to wear a certain way. But he also didn't seem like he really knew that much about the belts bc he said to take it off and turn it around and put it back on. I'm pretty sure that's a definite no no. He said it could cause premature wear and snap the belt but everyone on here says different. I have a brand new oem timing/balancer belt here that I never used. I'm not sure what to do.
Old Jan 19, 2012 | 06:19 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Right. Depending on how long the belt has been on,it is definitely worn in one direction now.
I would dump the Greddy belt and install the OE belt. The Greddy belt is for show and will not benefit you. Most, if not all, all-motor race Hondas and even turbo Hondas use OEM belts. There are very stout belts.
Old Jan 19, 2012 | 11:08 PM
6thGenJed's Avatar
not your belt. ^what he said about show is true.
Old Jan 19, 2012 | 11:09 PM
6thGenJed's Avatar
*your belt isn't the problem. not directional.
6thGenJed's Avatar
Old Jan 20, 2012 | 04:20 PM
phootbag's Avatar
OEM Honda tbelts are made by Gates.
JasonST
Aug 12, 2009 08:45 PM
2001accord
Apr 2, 2006 04:37 PM
rival12
Mar 26, 2004 12:14 PM
Epiphanicgurl
Feb 25, 2003 07:04 PM
