97 accord pas window randomly stops working help..
Old Jan 17, 2012 | 10:02 AM
steven.shutz's Avatar
Icon2 97 accord pas window randomly stops working help..
So my pas window randomly works.. I just replaced the master switch andthe motor is used salvage yard motor.. Why does it only work sometimes? Short? Old motor? What....!
Old Jan 17, 2012 | 03:50 PM
lazlong's Avatar
Default Re: 97 accord pas window randomly stops working help..
Look for broken wire(s) in the wire boot. It looks like a rubber accordion and is situated between the door hinges.
Old Jan 18, 2012 | 06:02 AM
krc91987's Avatar
As an owner of 3 different 94-97 accords, I will tell you that the window motors are a weak point in these cars, the mounts are in the middle of the window, instead of at each end so it always ends up with more friction on one end, which causes the motors to burn out prematurely. If you got one from a junk yard there is a pretty good chance it is on its way out too, I would look into a new one, or try to find a low mileage used one.
Old Jan 18, 2012 | 06:22 AM
TheMuffinMan's Avatar
He knows where you live!
Clean out and lubricate the window tracks and seals and purchase a new window motor...
Old Jan 18, 2012 | 11:08 AM
davidt1's Avatar
Silicon grease works wonder on sluggish windows. Both windows on my 94 Accord practically stopped working until I applied some silicon grease. Now they work like new.
Old Jan 19, 2012 | 03:35 PM
coloradonan5's Avatar
I know this a dumb question but where exactly was the silicon grease applied. Thankx.
Old Jan 19, 2012 | 04:18 PM
Use Honda Shin-Etsu Grease for all the rubber seals, this is a silicone based grease they use on S2000's and NSX's for their convertible and targa tops. It helps rejuvenate and lubricate the rubber seals. Clean out the seals and read the instructions (essentially wipe it on til it is absorbed)
For the actual metal rails, use a lithium grease (Honda has a spray) for these. Clean them out thoroughly before you just spray it though.
johm73
Oct 25, 2015 02:30 AM
marktheshark666
Dec 10, 2010 04:56 AM
mickyandmickey
May 12, 2008 05:13 AM
slim689
Feb 14, 2007 03:21 PM
acketon
Jul 2, 2006 11:01 PM
