OBD2A GS-R Swap into 1995 Civic Ex.
Old Jan 17, 2012 | 08:43 AM
Dedotut's Avatar
Default OBD2A GS-R Swap into 1995 Civic Ex.
Hello Honda-Tech! Ive been searching through google, Ht and other forums but couldnt find a solid answer. Well heres my scenerio. I have a complete OBD2A GS-R and i just swapped it into my 95' ex coupe. Im running a 94' OBD1 GS-R ECU, I have the OBD2A harness hooked up to the motor as well. Problem is i cant get it to turn over. Ive searched and found that i need an OBD1 distributor, injectors, alternator. Another question is, is it bad to run an OBD2 wire harness in a OBD1 car? Thanks Honda-Tech!!!
Old Jan 17, 2012 | 08:53 AM
B18CivicEJ8's Avatar
Default Re: OBD2A GS-R Swap into 1995 Civic Ex.
You don't need all that OBD1 stuff. The OBD2A Integra harness should work fine because it is a 2-piece design that splits at the shock towers just like the harness in your Civic. Everything is plug and play if you use the Integra harness in your chassis.
At this point, if you can't get it to turn over, you need to do the basic troubleshooting of checking for spark, fuel, then compression.
http://technet.ff-squad.com/hybrid.92-95.obd2.htm
Old Jan 17, 2012 | 08:58 AM
Dedotut's Avatar
Thank you so much for the reply! So i just have the OBD2 engine harness. Is that all i need ? Or the harness inside the car?
Old Jan 17, 2012 | 09:07 AM
No you don't need to switch out the harness inside the car. It's plug and play. Since you have an EX, you don't have to wire up VTEC, it should already be there. I'm not sure if your generation D series had a knock sensor. You may have to wire that up but it's one wire run to the shock tower in the stock location. You also may need to wire up the IAB (intake air bypass valve). But the IAB doesn't prevent you from starting the car. If your car doesn't start, then it's a spark/fuel/compression type of issue.
Old Jan 17, 2012 | 09:13 AM
Dedotut's Avatar
Okay, i will troubleshoot it, thanks so much for clearing that for me! Tytyty!
Old Jan 17, 2012 | 11:31 AM
HondaPartsHero's Avatar
Technical Hero
Yes you'll have to wire up knock as well.
Old Jan 18, 2012 | 09:58 PM
Dedotut's Avatar
Im getting a very weak spark from my distributor wires, any suggestions? Dizzy cap? Coil?
Old Jan 19, 2012 | 01:30 AM
Technical Hero
Check all your grounds as well to make sure they're clean and tight.
Old Jan 19, 2012 | 06:22 AM
wakajdm8732's Avatar
Make sure your plug wires are in the correct order too.
Old Jan 19, 2012 | 08:00 PM
Dedotut's Avatar
Thanks for all the reply's! And the grounds that i have already grounded on my car are, tranny to chassis, valve cover, thermostat.
Old Jan 20, 2012 | 09:27 AM
Dedotut's Avatar
Bump!
killaberna
Jan 31, 2015 11:49 AM
jdm_eg6kid
May 20, 2009 04:46 PM
EfSedanLove
18
Jan 7, 2009 03:10 PM
CiviCVuE
Mar 2, 2007 11:05 AM
EK Hybrid
Apr 28, 2003 11:16 PM
