d16z6 EF, smoking.
Old Jan 17, 2012 | 06:41 AM
PasseraD's Avatar
Default d16z6 EF, smoking.
Hey everyone,
I'm needing some advice, I've got a d16z6 in a 1990 EF. It recently started smoking when it got cooler outside, this last cold front, and now whenever my car idles, or runs at a mid range RPM it's smoking. White smoke, I fixed the valve cover gasket, it seemed to be leaking from above the headers, and burning off. For some reason that didn't fix the problem it is still smoking, is it possible for oil to come out of the headers and leak around the gasket?
Old Jan 17, 2012 | 06:55 AM
4drEF's Avatar
Keyboard Humorist
Default Re: d16z6 EF, smoking.
White smoke is radiator fluid/water.
In colder temps you will get condensation in your exhaust in the morning that will burn off and have white puffs of smoke.
After the engine is all warmed up and you have driven it a while, it shouldn't smoke at all.
If it does smoke white during normal driving, then you need to start inspecting your water and oil.
Get a block tester from your local auto parts store and keep an eye on your radiator fluid level.
Old Jan 17, 2012 | 07:02 AM
PasseraD's Avatar
The water level seems to be normal not low, and my oil isn't milky. :X
Old Jan 17, 2012 | 08:05 AM
4drEF's Avatar
Keyboard Humorist
Get a block test kit.
It will check your water for finite traces of exhaust gases.
EFlovin'
15
Aug 5, 2013 11:16 AM
solsi2000
Sep 9, 2009 08:07 PM
blue89hatch
May 7, 2008 06:29 PM
dr_latino999
54
Dec 27, 2005 06:48 PM
Layziebtnh055
10
Apr 16, 2004 02:22 PM
