Curious ignition timing concern..
Old Jan 17, 2012 | 04:03 AM
VTC_CiViC's Avatar
Default Curious ignition timing concern..
Last night I wanted to check the base timing of my wife's Integra, purchased it from somebody as a built boosted GSR so the motor has already been opened etc.. I went ahead and setup my timing light, jumped the SES connector and proceeded to check the marks on the crank, funny thing was, I coulnd't even get a reading. I ended up advancing the distributor fully and finally I could pick up a max of 6* BTDC, not good since the map calls for 16* at idle. To verify it wasn't a fluke, I upped the base timing in the map to 26* and re-checked the timing with the light, sure enough I had 16* BTDC at full distributor advance. So basically, I'm running the car 10* retarded from the map and I can't figure out why. I tore the valve cover off and verified TDC and the cam marks, everything lines up fine.
Suggestions?
Old Jan 17, 2012 | 12:42 PM
VTC_CiViC's Avatar
Default Re: Curious ignition timing concern..
Just pulled the car out of the shop, looked it over with some of the guys. Crank set to TDC (verified by crank mark & long extension resting on piston #1), verified both camshafts lined up and verified distributor rotor is lined with cylinder #1, everything mechanically appears spot on. Verified ignition map set to 16.50* from 0-1250rpm through 17.9in/Hg, map appears to be spot on. Fire the car up and check with two different timing light.. with the distributor advanced fully, maximum timing read is 6-7*
W-T-F...
Old Jan 18, 2012 | 08:42 PM
dylanrue's Avatar
Check it without the SES jumped and post what you get here.
This is peculiar lol.
Derrick_12341
Aug 10, 2018 07:03 AM
I CRX I
Engine Management and Tuning
May 27, 2010 12:23 PM
HTn00b
Mar 10, 2007 10:17 AM
bazookatooth
Apr 23, 2005 11:56 PM
rioninja
Aug 4, 2001 05:48 AM
