LS/Vtec (slash) GSR question
Old Jan 16, 2012 | 10:01 PM
guy_from_nerk's Avatar
Default LS/Vtec (slash) GSR question
My buddy has a 94 GSR, he was having some noise out of the head so he purchased a replacement GSR head. Upon him bringing it home I looked at it and noticed that it was from an LS/Vtec. The plug on the head has been inserted and ground down. My question is, can he use this head on his GSR block by simply runing the external oil line like a regular LSV or will he have an issue with it due to the block being a GSR rather then an LS
Old Jan 16, 2012 | 10:14 PM
famous323's Avatar
Default Re: LS/Vtec (slash) GSR question
take out the plug, if its welded use a drill and a easy out to take it out.
Old Jan 17, 2012 | 07:08 AM
Thats what I told him to do, the only issue is you can't see the plug at all. From the look of things whoever had the head previously took a grinder to it...
Old Jan 17, 2012 | 09:25 AM
DirtyDA9's Avatar
They probably had it welded and machined. To use the external oil line, you will have to plug the hole in the block as well, and use an ls head gasket.
Old Jan 17, 2012 | 11:31 AM
mike703's Avatar
please read before you give out false information...YOU DO NOT USE AN LS HEAD GASKET when mating a gsr head to a gsr block holy **** what is the world coming to
Old Jan 17, 2012 | 05:59 PM
Not to mention I stated that only 1 area of the head looks to be ground down. The rest of the head is dull aluminum looking while 1 spot is nice and shiny. He took the head to a machine shop today they inspected it and said the head is flush, they told him that he could drill the hole out as they didnt want to attempt it.
Old Jan 17, 2012 | 06:03 PM
mike703's Avatar
that tells you something right there. the machine shop doesnt want to attempt it because they are scared that they will **** it up and owe you a head. if i were you i would leave it alone and run the gsr as if it were an lsvtec with a sandwich plate and external oil line. good luck man.
Old Jan 17, 2012 | 06:07 PM
Haha it isn't my head so I'm definitley not touching it
Old Jan 17, 2012 | 06:08 PM
mike703's Avatar
thats what im talking about!!!
Old Jan 17, 2012 | 06:11 PM
famous323's Avatar
machine it out the only way, if you want to run it on a gsr again just measure the bore from a spare head and let the machinist know
Old Jan 17, 2012 | 07:08 PM
DirtyDA9's Avatar
Your a ****ing idiot, obviously you need to read, the gsr head has already been plugged for LSVTEC, and he asked about using an external oil line. God you're dipshit.
Old Jan 18, 2012 | 06:24 PM
DirtyDA9's Avatar
What did you end up doing?
Old Jan 18, 2012 | 08:31 PM
I didnt end up doing a damn thing, its not my head as I stated in the original post lol. Im not sure what my buddy is going to do, if I were him I would try sellin the head and getting one thats not haggard up
Old Jan 18, 2012 | 09:06 PM
DirtyDA9's Avatar
That might be his best bet. Or like I stated before, run the external oil line, plug the oil galley in the block, and use an LS head gasket.
Old Jan 19, 2012 | 03:51 PM
mike703's Avatar
^^^^please just stfu and shoot yourself in the face. you DO NOT USE AN LS HEADGASKET. holy ****.
Old Jan 19, 2012 | 04:24 PM
DirtyDA9's Avatar
You are seriously a fcking retard. Do you not see the part where it says the head is already plugged for LSVTEC!? That means if he doesn't plug the hole in the block it will leak! And if he does plug it and uses a GSR head gasket theres going to be an open hole in the head gasket. Stop posting you fcking retard.
Old Jan 19, 2012 | 04:34 PM
mike703's Avatar
so theres a hole in the gasket IT WILL STILL SEAL JUST FINE...what the hell is your point.
Old Jan 19, 2012 | 04:37 PM
DirtyDA9's Avatar
My point is you are an idiot and don't know what you are talking about, you should go learn something and actually do work on a car, then maybe you can post when you know what you are talking about. Until then, peace.
Old Jan 19, 2012 | 04:41 PM
mike703's Avatar
Really when i START working on cars huh. coming from a guy who is currently in the process of a build with a goal of 230hp with stock gsr cams. get the hell out of here.
Old Jan 19, 2012 | 04:44 PM
DirtyDA9's Avatar
Lol yet again you know nothing. I have more automotive knowlage in my left ******** than you can hold a candle to. I'm not gonna waste my time with your stupidity.
Old Jan 19, 2012 | 05:08 PM
mike703's Avatar
youre probably right i should just stick to what i do best....
Old Jan 19, 2012 | 05:57 PM
DirtyDA9's Avatar
Rubbing yourself off? That's cool I guess.
Fugly123
Aug 2, 2012 11:51 PM
94_civic_dx
Oct 22, 2011 04:48 AM
hspoon
Nov 22, 2007 01:07 PM
rafimos
Jan 25, 2007 08:23 PM
KiNG $h!t
Jul 8, 2004 09:06 PM
