Universal AEM EMS A/C prob in 1995 civic
Old Jan 16, 2012 | 07:42 PM
dide's Avatar
Default Universal AEM EMS A/C prob in 1995 civic
i just installed universal EMS 30-1900u in 95 civic hb with OBD1. I noticed that the calibration included in the software is using switch#6 (ground = on) for the A/C master switch input (ECU pin B5), and the EMS is using LS#6 to drive the compressor clutch.
problem is, no matter if the A/C switch is turned on or off, it always send ground signal, which means switch#6 is always on when igntion is on, so does the LS#6 and compressor clutch.
the only data is this wire measure 12v when the A/C master switch is turned off, and measure 0.5v when the switch is turned on. But still, both conditions send ground signal.
I also already tried using switch#7 and used this voltage difference from pin#B5 as the input reference, it works. Only problem is, it require minimal set rpm to turned on, but it won't switch off until the engine speed is lower than this set rpm.
Any other clue how to control the A/C?
Rocket09
Honda Civic (2001 - 2005)
Sep 15, 2018 12:02 PM
97hx91sihatch
Dec 29, 2011 04:40 PM
efyou
Oct 9, 2007 01:54 PM
rudebwoy
Jun 25, 2006 06:42 AM
