I need help finding a part for my JDM conversion
Yes I've searched but I don't think I'm seeing why I'm looking for
I'm looking for the (grommet?) the connects the bumper to the fenders and whatever bolt is used if there is one. I have the L shaped plastic peice that the bumper sits on top of, I just cant seem to find what goes in it to hold the bumper to the fender..
Thanks guys
Thanks guys
Actually. That's all you use. It slides on the plastic L bracket (Acura CLs, and Accords use this L shaped plastic also.) you pop in the L piece with the square fitting that goes into the bumper and slide on. that's it, unfortunately.
If I'm misunderstanding you, please show me a picture and I can help further.
There is actually a plastic piece that is in the fender and a screw that goes through your bumper into the fender piece. I just bought a complete Jdm front and both sides had them, the Usdm has basically the same thing. If you are super picky you could probably just pick some up at your local Honda dealer. If you are not so picky you could just use a 10mm nut and bolt
Ah, yes, I know what you're talking about now.. my apologies. Its what closes that "gap" that is created between the fender and the bumper in the actual fender well. I didn't get THAT picky, I used a 10mm screw from the Honda dealer to do that. Its where the fender well liner is.. Gotcha..
Kicker773
Jul 9, 2003 08:28 AM
