b18c1 w/ p30 head milling
hey guys so i got all my parts to build my block finally just waiting for my crank at the machine shop and then ill post some pictures of my build. i gotta question if anyone can answer.
b18c1
ls crank
ls rods
p30
b16 head
s2p2 cams
im trying to get the compression higher by using a 2 layer headgasket, wondering if i take .020 off the head if the p2v clearance would be sketchy... anyone done this??
b18c1
ls crank
ls rods
p30
b16 head
s2p2 cams
i should b at 11.6 and i wanna be in the 12's im using skunk2 pro 2 cams and i would like all the compression i can get. If i can mill my head and get a few extra HP then why not?
I agree (on a build like yours). I would clay the valve pockets and see what your clearance is. As long as you're running stock size valves, you should be ok but I would check on those pistons... Usually V2V is the biggest concern.
thanks bro claying a head is what its gunna have to come down too unless i can find someone with a similar set up... come on people i kno theres about 100 people who have done this exact same thing
i don't know if this helps but i have a JDM GSR thats been milled 0.020" total and im using P30s and oem head gasket for 12:1 CR with no P2V issues. V2V might be an issue with those cams but milling the head shouldn't change the V2V?
monkeyboy313@hotmail.com
10
Mar 13, 2007 03:17 AM
