Miata rims on Civic,does it fit?
Old Jan 15, 2012 | 05:28 PM
kawaihaeeg6's Avatar
Default Miata rims on Civic,does it fit?
Does the mazda miata rims 4x100 hub match the civic/integra hubs? came across some 15x9 +38 offset Konig wide opens for a great deal in hawaii which is rare to buy rim and tire package brand new for $900, shipping alone is almost $200.Any advice would be greatly appreciated! Mahalo(thank you) for reading this.
Old Jan 15, 2012 | 06:16 PM
redm3turbo's Avatar
Default Re: Miata rims on Civic,does it fit?
depends on year...prior to 2000 im sure fits...after Im not sure...look on tirerack
Edit (see below) they fit, you DO need to shave a bit of the inside though...
Old Jan 15, 2012 | 06:17 PM
fonkernuckle's Avatar
I bought some miata rims after researching and listening to fools saying they would fit, but guess what they did not. They were stock oem ones.
Old Jan 15, 2012 | 06:21 PM
grumblemarc's Avatar
The Grumpiest
Well that's what I have read. Stock will NOT fit. Aftermarket 4x100 are something else totally. But 9" wide rims? Really?
Old Jan 15, 2012 | 06:35 PM
It's a 99, right on thanks,dont want to buy something that wont work.
Old Jan 15, 2012 | 06:41 PM
Only going with the 9" rims cause of the price! brand new shipped to hawaii 15"x7"+30 offset with 205/50/15nitto's $1300 plus shipping,and no one has a set of wide opens on my island yet.Mahalo(Thank you) for the comment.
Old Jan 15, 2012 | 06:43 PM
just found out that aftermarket pre 2000 miata's rims fit,oem stock does not.Mahalo(thank you)for the comment.
Old Jan 15, 2012 | 07:02 PM
NotAJDMFanBoy's Avatar
Which Civic? Some EX's, Si's, and the Del Sol VTEC had larger front brakes. The back or the spokes could scrape also though. I don't know where I'm going with this.
Old Jan 16, 2012 | 04:12 AM
redm3turbo's Avatar
I just called a buddy of mine who had pre 2000 miata rims on his crx for years....he says they fit, however you have to bore out the center just a tad to get them on the hub...
Not really a huge deal, and usually miata rims you can get cheap. Just grab a dremel or whatever and shave off a little inside.
Old Jan 16, 2012 | 07:15 AM
Those rims look pretty good on that crx for stockers,thank you for all your input.. Glad to see there are alot of helpful people on this forum,thank you guys for all the helpful info
Old Jan 16, 2012 | 07:21 AM
it,s 92 eg6 vx model. Iknow the stok 14" miata rim dosent fit with the rear disc conversion,but i'm hoping that the 15" aftermaret rim will clear the calipers.
Old Jan 16, 2012 | 08:59 AM
Will_GT90's Avatar
Before getting HX wheels I was looking into some Miata wheels, this site may contain some info on size/backspace of miata wheels and things that will fit miatas : http://www.miata.net/faq/wheel_weights.html
Make sure you know what backspacing your civic needs first, can do that here:
http://www.tirerack.com
Old Jan 16, 2012 | 11:15 AM
98civdx's Avatar
Master Detailer
They DO fit, however, as the poster above me said, you have to bore out the center hole.
The hole in the Miata wheels are a bit smaller.
I would stick with a Honda wheel, something you know will fit without any work.
Old Jan 16, 2012 | 06:25 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
I don't know why they wouldn't, my VX rims fit with a rear disc swap
Old Jan 16, 2012 | 08:31 PM
chiprez's Avatar
^this^
Something about spending money on wheels then haveing to hack them up to fit doest sound to appealing. Found this out when i was looking t=into the 14x7 rpf-1's that are intended for Miatas.
Old Jan 17, 2012 | 05:12 AM
redm3turbo's Avatar
^ those Rpf-1's should of fit....aftermarket wheels (in 4x100) from miatas tend to work.
Old Jan 17, 2012 | 05:23 AM
Crx_JDMWhore's Avatar
i have them on my ef..but i had to carve out the center , where the center cap would be.. but yea... you SLAMMM it with those on there.. just say
Old Jan 17, 2012 | 01:13 PM
EK-Chris's Avatar
I had the same setup on my 92 VX.
pr_boricua9
Suspension & Brakes
13
Sep 29, 2016 09:45 AM
DaMenaCe
Oct 15, 2010 06:04 AM
retro1
Acura TSX
Mar 11, 2010 02:05 AM
uses0ap
Aug 16, 2008 03:19 AM
JHondaEJ
May 22, 2008 08:30 AM
