spark plug broke inside ep3
Old Jan 15, 2012 | 03:42 PM
Dan@DFR's Avatar
Default spark plug broke inside ep3
so a friend was trying to pull out his seized spark lug out of his ep3 and ended up braking it inside so i need some advice on how to take it out and if it can be done with out taking off the head?? thanks in advance for the help
the one on the right is the broken plug
[IMG][/IMG]
Old Jan 15, 2012 | 05:30 PM
vtecnique69's Avatar
Default Re: spark plug broke inside ep3
ouch. I'm not sure if they make them big enough, but maybe some type os (screw) extractor bit in a socket on an extension?
If not, I would assume the head would have to be disassembled.
Old Jan 15, 2012 | 06:14 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
should be using those shitty bosch platinum +4 bullshit plugs in the first place... also probably didn't use any anitseize
Anyways... thats a tough spot... horrible break... I doubt you'll get that out without the head being taken off truthfully. The K series plug tubes are really long making it a pain to get anything down there.
Old Jan 15, 2012 | 06:24 PM
dstnbmxvr6's Avatar
they make a kit for the ford 5.4 3 valve engines that is specifically for this, i have one and if you were local i'd help you out, check out this
http://www.summitracing.com/parts/KTI-75201/
it may or may not fit down inside a K, but its worth a shot.
Old Jan 29, 2012 | 04:32 PM
stclair87's Avatar
you can get a bolt out that big enough to fit in the broken metal neck. get some penetrating oil on the stuck plugs threads let it sit then use the easy out. ive used the trick before works great
RecklessEJ
Apr 30, 2012 08:13 PM
imzjustplayin
Dec 22, 2008 01:01 PM
GSR_hatch936
Oct 23, 2008 09:36 AM
sfr4dr
Jan 19, 2004 03:53 PM
nek0
Jul 22, 2003 04:07 AM
