Bellowing white smoke upon start up. Please help -- for the techs
Old Jan 15, 2012 | 12:16 PM
J-GOT-M's Avatar
Icon2 Bellowing white smoke upon start up. Please help -- for the techs
Before getting flamed...I'm new and did a search. Found similar problems but not my exact problem...
I bought a stock EK civic hatchback 1996 with 160k miles about 3 weeks ago. I need a daily driver that gets hybrid miles per gallon so don't plan on modding. I'm getting 400+ to the tank so it's doing the job. (mention this b/c there is no power loss or loss of efficiency)
The past few mornings the car has been bellowing white smoke upon start up. It continues to blow white smoke until the car warms up and then goes away. It doesn't do that after parking and restarting (later in the day) just start up in the morning. I've noticed in my rear view but tomorrow I will go for smell test. I live in northern Virginia so it's been cold lately.
To my understanding it could be cracked/blown hg, valves, or something else. The problems I've read didn't specify if the problem continued after warming up or not or after restarting. My issue is only first thing in the morning and stops after warming up. Stock motor and I've already replaced timing belt, water pump, tensioners, oil pan gasket (leak), and oil.
Any help or thoughts would be appreciated.
Old Jan 15, 2012 | 12:18 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Please help -- for the techs
It's been real cold these past mornings. Do a compression test if you must but it sounds normal to me.
Old Jan 15, 2012 | 12:23 PM
motegicivic's Avatar
How is the temp gauge, does it go past half way?
Just for peace of mind do a block test.
Old Jan 15, 2012 | 12:25 PM
J-GOT-M's Avatar
Temp gauge stops a little below halfway.
Old Jan 15, 2012 | 12:27 PM
J-GOT-M's Avatar
The smoke isn't the typical cold air morning smoke. It leaves a trail behind me and can be seen in my rear view mirror.
Old Jan 15, 2012 | 12:42 PM
The Grumpiest
So does mine when it's as cold as it's been.
Old Jan 15, 2012 | 12:44 PM
HondaPartsHero's Avatar
Technical Hero
Yeah same here, sounds normal
Old Jan 15, 2012 | 01:50 PM
Kohen's Avatar
Default Re: Bellowing white smoke upon start up. Please help -- for the techs
you should be okay. when you start up your car and it's cold out, it's normal to have smoke coming out.
if you're that worried about it, perform a compression test and leakdown test. post the results.
Old Jan 15, 2012 | 02:17 PM
J-GOT-M's Avatar
Ok--sounds like this happens to others. I guess I'm just not used to seeing all this smoke. Thanks for the input.
Old Jan 15, 2012 | 02:24 PM
The Grumpiest
Steam.
Old Jan 16, 2012 | 01:06 AM
sde780's Avatar
Condensation buildup in your exhaust when it sits overnight.
Inf^Shini
Oct 30, 2007 09:27 PM
Dat_One_Si
Oct 22, 2006 06:50 AM
viper_2_4
Aug 15, 2006 09:51 PM
danny98r
Oct 5, 2004 01:22 PM
brian2903
May 20, 2004 04:32 PM
