93 DX - won't start after head work and head gasket replacement
Old Jan 15, 2012 | 10:15 AM
Mike95Civic's Avatar
Default 93 DX - won't start after head work and head gasket replacement
Well this is my sisters car. We swapped a 94 d16z6 engine into it, it had a bad headgasket. It ran like ****. I took the cylinderhead off, cylinder#2 had a decent chunk out of the exhaust valve. So i replaced the valve, got the cylinder head resurfaced.
I put it all back together 2 days ago, and now the engine turns over, but it doesn't wanna start. It sat for 2 weeks. Now, i might need some help with this, because i know the vacuum lines are different in both vehicles.
Does any one know what this could be?
PS: ohhh and it SOMETIMES starts, rarely. It'll run when im hitting the gas pedal. But if i dont touch it, it stalls. It also runs like complete ****.
Old Jan 15, 2012 | 10:22 AM
grumblemarc's Avatar
The Grumpiest
Default Re: 93 DX problems
Timing?
Old Jan 15, 2012 | 10:27 AM
i will double check the timing
Old Jan 15, 2012 | 10:28 AM
it also gets fuel and spark
Old Jan 15, 2012 | 10:29 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Check the ground on the thermostat housing.
Old Jan 15, 2012 | 10:55 AM
94EG8's Avatar
Seagull Management
Besides this and what marc said, check to make sure you plugged the engine harness in tight at the shock tower plugs. I once spent a couple of days trying to figure out why a swap would barely start and run, turns out I didn't plug the middle 4 wire plug on the driver's shock tower in tight and only 2 injectors were firing. I've also had issues with the thermostat ground before as well.
Old Jan 15, 2012 | 02:57 PM
Default Re: 93 DX - won't start after head work and head gasket replacement
i didnt touch the engine harness, only the plugs for the evac solenoid, map sensor, tps sensor, IACV
Old Jan 15, 2012 | 03:17 PM
B18C5-EH2's Avatar
Former Moderator
Loved
...so you didn't even replace the thermostat?
Old Jan 15, 2012 | 03:34 PM
94EG8's Avatar
Seagull Management
It's been a while since I've done one of these, but I'm almost positive the you don't need to remove the thermostat ground bolt to remove the thermostat. IIRC there are two bolts that hold the two halves of the housing together and a third bolt for the ground.
Old Jan 15, 2012 | 03:36 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Right, but a lot of people remove it anyways. I just unbolt the two and leave the hose attached to the half housing, then split it apart.
I was also more or less seeing if the guy did a head gasket job and kept an old t-stat.
Old Jan 15, 2012 | 04:15 PM
Former User's Avatar
If the T-stat ground is loose or disconnected, then there will be no spark or fuel (assuming OP really tested for both). In this case, focus on the mechanical timing and whether the plug wires are installed in the correct firing order.
Old Feb 19, 2012 | 11:48 AM
i replaced the MAP sensor, and i realized i had put some connector plugs in the wrong spots.
She runs good now, thank you all for your generous help!
Also thank you RonJ@HT for the diagrams. Now i don't have to keep searching on google haha.
Moderators may delete this thread.
Old Feb 19, 2012 | 01:54 PM
B18C5-EH2's Avatar
Former Moderator
Loved
No way bro. This can serve as a helpful tool for those who search for a similar problem on their own vehicles.
Glad it worked out for you
Old Feb 20, 2012 | 01:56 PM
ahhh fair enough lol
and thanks man, I'm just used to working on my stealth, not a honda lol.
Also, it already had a new T-stat... headgasket was leaking oil badly, cylinderhead was warped.
deepfriedjinx
Aug 26, 2024 01:01 AM
CD0419
Honda Civic (2001 - 2005)
Oct 21, 2017 09:23 PM
S_F
34
Nov 22, 2012 10:54 AM
TigerLy
Jan 1, 2012 07:29 PM
Strikerrr
Aug 5, 2005 07:18 AM
