Help me out with this swap!!!
Old Jan 15, 2012 | 07:31 AM
guachi1209's Avatar
Default Help me out with this swap!!!
I need help with swaping in a b20B into a 97ek
i have done 2 b16 swap a ls swap and changed some single cams so
i have a idea on what to do, now its time to swap a b20b with a b16 tranny in my 97ek but my friends are telling me its not as simple as a b16 and there are something im going to have to change before being able to run it...so before i start is there anything i should know about a b20B swap
Here is my list....
-b20b from (hmotorsonline)
-b16 tranny from my old si
-ek hasport motor mounts
-gsr shift linkege
-2000 si axles
-p28 ecu
-step down harness 0bd2-0bd1
is there anything else i many need or have to change on the motor/tranny
to make it run in my ek???
Old Jan 15, 2012 | 09:25 AM
dascivic96's Avatar
Default Re: Help me out with this swap!!!
i just picked up a b20b myself and im putting it into the same car.
pretty sure you will need the t bracket from a 99-00 si as well.
and its always good to go full size radiator if you dont already. dont have to, but your motor will like it more.
good luck man! trying to gather up parts for my build as well.
Old Jan 16, 2012 | 06:18 AM
guachi1209's Avatar
yea i do have the bracket forgot to list that....but thanks bro
did you use the same TB,intakemen cuz i been told the throttle cable is backwords on this motor i got the 99-00ver
Old Jan 16, 2012 | 07:07 AM
kyden's Avatar
you're gonna need the si mount bracket on the drivers side also.
throttle cable goes the same way as a non-gsr. gsr is the only one that mounts differently.
Old Jan 16, 2012 | 12:32 PM
guachi1209's Avatar
well right now i have a b16a2 in my car so i have the si bracket and the t-bracket i just hope all i would have to change is the b16 long block for the b20 long block
Old Jan 16, 2012 | 08:53 PM
dascivic96's Avatar
did yours come with the giraffe style intake mani?
Old Jan 17, 2012 | 06:22 AM
guachi1209's Avatar
how can i tell the differnce between the two mani
Old Jan 17, 2012 | 11:42 AM
dascivic96's Avatar
the giraffe style is just reallyt all, as where the other isnt, if you got the giraffe one you will need to switch it out. the hood wont close with it, ill try to post pics to show you the difference.
Old Jan 17, 2012 | 11:53 AM
dascivic96's Avatar
there you go, giraffe style is one on left, 94 ls on right.
Old Jan 17, 2012 | 12:30 PM
guachi1209's Avatar
i guess i got lucky cuz i got the ls one does that mean i dont have to change the mani or the TB???
Old Jan 17, 2012 | 01:09 PM
dascivic96's Avatar
you probably dont have that one, those dont come on b20s normally, but no if what you have on there isnt the giraffe one you should be good to go. mine didnt come with giraffe style either, mine came with the P75 intake mani.
there should be stamp on yours thatll tell you which one it is.
post a picture of the stamp or just look it up if you dont already know what one you have.
khoolie
Mar 2, 2011 04:34 PM
dth0ng69
Oct 8, 2009 09:12 PM
Tom123456
Dec 14, 2006 01:11 PM
typesguy
Jan 29, 2004 06:53 AM
