need help...wich harness?....b16a into 90 EF hatch...
Old Jan 14, 2012 | 07:35 PM
em1effekt's Avatar
Default need help...wich harness?....b16a into 90 EF hatch...
im working on an ef hatch...
now has a b16a motor in it..but i am confused on wich harness to use?
i was told to use the stock ef d15 harness...the engine is obd1 the ecu is pw0
Old Jan 14, 2012 | 08:01 PM
em1effekt's Avatar
Default Re: need help...wich harness?....b16a into 90 EF hatch...
bump for some help
Old Jan 14, 2012 | 08:04 PM
crx_si-r's Avatar
Use your stock harness and and modify it. Since your ecu is obd0 then you will also need to make sure u have a matching distributor. Makes no difference that the engine is obd1, what matters is that the distributor matches your ecu.
I'd addition to this you will also need to do the DPFI (dx) to mpfi (Si) conversion in addition to adding in vtec.
Old Jan 14, 2012 | 08:13 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
As with all swaps and as stated before - use the harness that came with the vehicle and modify it as necessary. Also, please don't bump - it's against the rules...
http://htarchive.org/showthread.php?t=2086185
Old Jan 14, 2012 | 08:22 PM
em1effekt's Avatar
Thanks for the help..but what do you guys mean modify the harneess?
Is there a easier route to go?..using another vtec harness?
Old Jan 14, 2012 | 08:31 PM
crx_si-r's Avatar
Your stock harness is set up for 2 injectors. Your new motor has 4. You need to modify your harness for 4 injectors.
The easier route would be, buy a conversion harness. Check my Facebook link below
Old Jan 15, 2012 | 05:44 AM
DO IT ON ALL FOURS
Hurting for money there guy? This conversion has been done millions of times. Take a look in the FAQs as there is probably 5 or 6 "How-TO's" on this let alone if you searched te Google...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
Old Jan 15, 2012 | 06:53 AM
91EFH22's Avatar
Yeah the change over is pretty basic IF you follow directions. As Never said to me, a lot can be learned from GOOGLE/SEARCHING....
Old Jan 20, 2012 | 01:47 PM
PrincessEF9's Avatar
I have a D16a6 and i was told the wiring harness was completely transferable for a b16a.
Old Jan 20, 2012 | 03:11 PM
crx_si-r's Avatar
https://honda-tech.com/forums/showthread.php?t=1508680
No sir. Are u?
I just offer an alternative to used harnesses.
Old Jan 21, 2012 | 04:18 AM
BiGZ's Avatar
Modify vehicle's orig harness (unless ya like to replace under dash/cabin harness-NOT fun!) BTW,dizzy,ecu,AND injectors must match (ALL covered in the FAQ,search mpfi conversion)
Old Jan 21, 2012 | 05:37 AM
crx_si-r's Avatar
Um, no. Only ecu, distributor and o2 sensors have to match. Injectors do not have to be obd1. You can use obd0 indicators with an obd1 ecu, and vice versa
90civicbns
Jul 17, 2013 11:41 AM
0ne-Cam
Jun 30, 2013 07:39 PM
0ne-Cam
Sep 25, 2009 08:42 AM
TurboGoKart
18
Mar 30, 2007 11:11 PM
