I need help installing a power steering pump
Old Jan 14, 2012 | 05:53 PM
Agguhnitus's Avatar
Default I need help installing a power steering pump
I have a 1993 EG6 with a B16a2 that doesn't without power steering. I just purchased a power steering pump without the power steering tank (or the reservoir tank). I've seen a power steering tank on Ebay but it claims that the tank can be put on a b16 or a b18. I would like to know if the power steering tank can be interchangeable with a B16 and a B18. Should I get one that is specifically for a b16a2? Please HELP!
Old Jan 14, 2012 | 07:18 PM
94EG8's Avatar
Seagull Management
Default Re: I need help installing a power steering pump
What rack and lines do you have? If it's got the original civic rack get one for any '92 - '95 Civic, If you used a '94 - '97 Integra rack and lines get a reservoir for that. The original D-series pump is exactly the same as the OBD1 B16A pump btw, along with the '94 - '97 Integra pump.
Old Jan 14, 2012 | 07:59 PM
NotAJDMFanBoy's Avatar
All the tanks look the same to me. They mount in the same spot. Just get one for the chassis the rack and pump came from. Or just do what I do when I have a question about what will work and check the acura and honda dealership sites for part numbers and see if they're even different.
Old Jan 15, 2012 | 03:44 AM
94EG8's Avatar
Seagull Management
Integra has an extra nipple on the reservoir, I found out the hard way when I swapped an Integra rack into my civic (also found out the hard way I needed the integra lines)
Old Jan 25, 2012 | 04:25 PM
Agguhnitus's Avatar
Sorry I havent reponded, my laptop died on me so I had to get it fixed. I got the lines off a '92-'95 Civic EX as well as the reservior tank. I have the top rack off a B16 but i dont have the lower rack. Will this be an easy install on a CX Hatchback?
Old Jan 25, 2012 | 05:14 PM
94EG8's Avatar
Seagull Management
Top rack? Lower rack? What are you talking about?
Old Feb 15, 2012 | 06:30 PM
Agguhnitus's Avatar
I dont have the racks at all. I feel like an idiot because I didnt know what you meant but i do now. What I meant to say is that I have the top bracket. I think I need the pinion as well right?
Old Feb 15, 2012 | 06:49 PM
78F350's Avatar
Here are some parts diagrams that may help. Its hard to figure out exactly what you are asking.
http://www.hondaautomotiveparts.com/...gry5=P.S.+PIPE
http://www.hondaautomotiveparts.com/...=P.S.+GEAR+BOX
AntraxL1
Honda Civic (2001 - 2005)
Aug 24, 2014 10:01 AM
Raiderz8418
Jan 26, 2012 01:03 PM
b16ekinva
Oct 23, 2008 05:23 PM
Nippo
Jan 20, 2008 07:51 AM
