D16A6 with D16Z6 parts possible?
Old Jan 14, 2012 | 05:53 PM
Wilmer787's Avatar
Default D16A6 with D16Z6 parts possible?
Ok' this is what happend to me, Had a D16Z6 complete engine on my car but the corrosion killed my block around the sleeves. A friend of mine gave me a D16A6 block to replace my Z6 block and use all the z6 stuff in the A6 block, I have bought a timing belt kit for a 92-95 D16 block and now I saw that the A6 block use a different timing belt, tensioner and water pump, I searched for the Z6 vtec head swap and everybody uses all the A6 stuff using the Z6 head. My question is can be possible to use all my Z6 timing belt kit(104t belt, the small timing belt tensioner and water pump and get everything matched on the A6 Block? Thanks for looking Guys'
Old Jan 14, 2012 | 07:19 PM
94EG8's Avatar
Seagull Management
Default Re: D16A6 with D16Z6 parts possible?
What's the A6 use for belt? 106 teeth? I'm almost sure you need a Z6 belt with a Z6 head.
Old Jan 15, 2012 | 03:51 AM
Wilmer787's Avatar
A6 uses a 107t
Mr learns alot
10
Dec 16, 2013 09:44 AM
Wilmer787
Jan 15, 2012 10:00 AM
Contender25
12
Sep 12, 2011 01:36 PM
nickeynick
Dec 8, 2007 09:19 PM
pinoy369
Apr 24, 2007 06:00 AM
