Suspension upgrades that make a difference. (long post)
I have an integra 4 dr (DB7) and am looking to improve handling. I've already decided on koni yellows and ground controls for my shocks & springs. This is my daily but will be used for some road racing (time attack).
After some extensive research and reading, I've come up with the following:
LCAs- Do nothing, just shiny pieces of metal with new bushings. Better to invest in some new hard rubber bushings with OEM LCAs.
Subframe brace- Useful only if used with a 20mm+ rear sway bar.
Beaks lower tie bar-better off going with a subframe brace
front solid shock tower bar- gives better steering response
Front sway bar-usually causes more understeer depending on spring rates.
Sticky tires-essential for high speed cornering
My question is if I get high enough spring rates (ie 450lbs or higher), will a 20mm+ rear sway bar still be beneficial on a street car?
Any chassis or suspension pieces I'm missing that would complement konis/GCs?
For your question, the rear bar and it's influence will depend on the spring rates for. Oth front and rear. You told us 450+# springs but where? Front, rear or all around? Need to know this first.
If you actually plan on seeing any track with this car, just go to the track and start learning your car. Then start building the suspension for your needs and driving styles.
Not sure. Thinking 450f/500r to compensate for a lack of a bigger rsb? Thoughts?
Any other worthwhile parts that would stiffen up the chassis short of a cage?
there are unlimited amount of suspension setups that have been proven to work well with our cars. weather its a jdm front bias or a typical American rear bias setup. but in the end its your car that your driving and you need to build your setup to compliment your driving style. for now your money will be much better spent on track days. learning your car and getting seat time. then once your suspension is the limiting factor that is slowing you down, rather than your skill as a driver, you can start to build a suspension setup that works for you. have fun!
Bushings might be a good idea, considering the age of our cars. I personally went with Hardrace and like them but, the other choice would have been OEM.
Falloutkid90
14
Jul 21, 2015 05:31 PM
kaiba
Nov 24, 2005 09:50 AM
ill phil
19
Sep 23, 2003 01:35 PM
hondacivic4g
10
Nov 6, 2002 03:11 PM
