turbonetics fuel controller, msd btm, autometer, turbonetics Fuel controller
turbonetics FIC setup, ( comes with fic, 2bar map sensor and 2 venom 440 injectors) that kick in once the map sensor reads boost and the fic adjusts the spray of the 2 additional injectors based on the boost. came off a 2000 civic si, but pretty universal. very simple to install.. the fuel y to the injectors and the a power a ground and splice into the map signal. This was high tech back in the day and came in the turbonetics kits that ran around $4k, aloud you to run 20psi. something a vafc couldnt do and a fmu wasnt safe enough to do.. .. will include the piece of charge pipe with the bungs and injectors but NOT THE BOV!!!!!!!!!!!!!!!!! The pipe will be cut 4 inches behind the bov.
$$$$$$$$$$$$$$$$150$$$$$$$$$$$$$$$$$$$$$
autometer pro comp liquid filled fuel pressure gauge.. numbers are kind cracked looking but works 100%
$$$$$$$$$$$$$$65$$$$$$$$$$$$$$$$$$$
autometer big face water temp gauge with all the wiring and box, clip etc.
$$$$$$$$$$$$$$$$$$$$$80$$$$$$$$$$$$$$$
new Emusa D17 t3 turbo manifold with external w/g flange
$$$$$$$$$$$$$$$$$75$$$$$$$$$$$$$$$$$$
RARE mugen fiberglass lip kit for crx (ONLY FITS MUGEN OR MUGEN REPLICA CRX BUMPER COVER) need work to be perfect..
$$$$$$$$$$$$$$$$$80$$$$$$$$$$$$$$$$$
msd boost timing master with **** and all the wiring
$$$$$$$$$$$$$$100$$$$$$$$$$$$$$$
jackson racing air fuel ratio gauge
$$$$$$$$$$$$$$40$$$$$$$$$$$
Trades excepted
Trades excepted
injector driver came from a 3,700 dollar turbonetics kit.
http://www.prostreetonline.com/a/acu...turbo-kits.asp
the msd btm also came in that kit.
"Sport Compact Racers like Matt Scranton, Christian Rado, and Ara Arslanian crush the competition with Turbonetics turbos and now you can too. These complete turbo kits come with everything you need to make big power - up to 260 horsepower on a stock 1994-2001 Integra GSR! Built around Turbonetic's T3/T4 hybrid, the kits deliver fast boost response and high airflow capacity. The kits come with, Lucas 440cc injectors with pre-programmed injector driver, map sensor, and vent lines. Complete with all hardware and installation instructions needed to turn your car into a fire breathing racer!"
pheonixb16aguy@hondaswap
Jan 23, 2012 06:43 PM
doberwing
Apr 5, 2004 07:45 PM
