d17 turbo mani, msd btm, autometer, turbonetics Fuel controller
turbonetics FIC setup, ( comes with fic, 2bar map sensor and 2 venom 440 injectors) that kick in once the map sensor reads boost and the fic adjusts the spray of the 2 additional injectors based on the boost. came off a 2000 civic si, but pretty universal. very simple to install.. the fuel y to the injectors and the a power a ground and splice into the map signal. This was high tech back in the day and came in the turbonetics kits that ran around $4k, aloud you to run 20psi. something a vafc couldnt do and a fmu wasnt safe enough to do.. .. will include the piece of charge pipe with the bungs and injectors but NOT THE BOV!!!!!!!!!!!!!!!!! The pipe will be cut 4 inches behind the bov.
$$$$$$$$$$$$$$$$150$$$$$$$$$$$$$$$$$$$$$
autometer pro comp liquid filled fuel pressure gauge.. numbers are kind cracked looking but works 100%
$$$$$$$$$$$$$$65$$$$$$$$$$$$$$$$$$$
autometer big face water temp gauge with all the wiring and box, clip etc.
$$$$$$$$$$$$$$$$$$$$$80$$$$$$$$$$$$$$$
new Emusa D17 t3 turbo manifold with external w/g flange
$$$$$$$$$$$$$$$$$75$$$$$$$$$$$$$$$$$$
RARE mugen fiberglass lip kit for crx (ONLY FITS MUGEN OR MUGEN REPLICA CRX BUMPER COVER) need work to be perfect..
$$$$$$$$$$$$$$$$$80$$$$$$$$$$$$$$$$$
msd boost timing master with **** and all the wiring
$$$$$$$$$$$$$$100$$$$$$$$$$$$$$$
jackson racing air fuel ratio gauge
$$$$$$$$$$$$$$40$$$$$$$$$$$
Trades excepted
Trades excepted
pheonixb16aguy@hondaswap
Jan 15, 2012 07:08 AM
doberwing
Apr 5, 2004 07:45 PM
