Axle too short
Old Jan 14, 2012 | 01:39 PM
ppjl's Avatar
Icon2 Axle too short
I replaced the front axles on my 1987 CRX and when I took it out for a test drive it stopped and acted like it was out of gear. When I checked it out the drivers side axle had popped out of the tranny just enough to disengage the splines. I went back to the parts store and we checked the length of the axle against his book and it should have fit. Has anyone had the type of experience?
Old Jan 14, 2012 | 01:49 PM
Dc4LsTeG's Avatar
EK9
Default Re: Axle too short
Are you sure you installed it right
Old Jan 14, 2012 | 01:54 PM
ppjl's Avatar
Yes
Old Jan 14, 2012 | 02:09 PM
Dioxine's Avatar
No offense, but im willing to bet that you didnt snap it in all the way. Try again if it should fit. Cause once an axle it properly in it should pop out.
Old Jan 14, 2012 | 03:17 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You shouldn't see any "shiny" part of the axle (the journal where the seal rides).
Also, this may be better to ask in the correct Forum as this is the 1988-1991 Forum. There is a forum dedicated to the Pre-'88 Hondas.
Old Jan 14, 2012 | 04:00 PM
acmoc's Avatar
do you have the old axle?
Old Jan 16, 2012 | 06:43 AM
ppjl's Avatar
So where do I find the pre 1988 forum?
Old Jan 16, 2012 | 06:45 AM
ppjl's Avatar
I've been doing some more checking on this and I believe I have the wrong axle. When the retaining ring "pops" in to the tranny the outer end is too short at the spindle end.
Old Jan 16, 2012 | 09:58 AM
DO IT ON ALL FOURS
Here it is...
https://honda-tech.com/forums/classic-hondas-106/
...but it can also be found on the main Honda-Tech page.
withoutlimitslude
29
Apr 1, 2022 03:21 PM
Josh7x
Feb 11, 2011 10:56 AM
killacam661
Transmission & Drivetrain
Jan 4, 2009 03:17 PM
xingyun
Nov 30, 2008 02:06 PM
The Dirty EJ1
Sep 3, 2007 04:34 PM
