OBD2 to OBD1 Jumper harness issue
Old Jan 14, 2012 | 12:27 PM
shahriar35's Avatar
Default OBD2 to OBD1 Jumper harness issue
My OBD2 to OBD1 Jumper harness has caused my RPM gauge not to work. I have searched and have not found a exact answer how to fix the issue. I have heard that you have to change certain pins or at least one pin. Thanks in advance.
Old Jan 14, 2012 | 01:09 PM
94sicteg's Avatar
Default Re: OBD2 to OBD1 Jumper harness issue
look what i found for ya look for the A19 wire jumpered with the OBD2b B13.....all going to OBD1 A21 .
look at the 26 pin connector , pin number a21 and a25 tap in a 1k ohm resistor between the wires
or last run a wire from the engine bay connector should be a blue wire from the distributer to the connector , now from that connector run a new wire to the ecu pin a19 tach input
hope this helps there seem to be a few remedies
my1992cb7accord
Dec 15, 2011 09:47 PM
Momentum
Aug 13, 2010 07:11 AM
civic006
Jul 14, 2010 01:50 PM
2nrz
Jan 21, 2008 08:11 PM
b20_vtec_integra
Dec 2, 2004 04:39 PM
