Header Glowing Red after 90 seconds. New k build
Old Jan 14, 2012 | 09:24 AM
Sp00nFed EM1's Avatar
Default Header Glowing Red after 90 seconds. New k build
Here's the rundown on the car:
Stock K20z3
97 Ek coupe
JDM ITR ecu (fuel pump grounded)
11.7:1 wiseco
Center feed fuel rail tucked with return off the regulator
Cylinder runners 2 and 3 were glowing red hot after only a few minutes. This was the second start up. First time I was off timing on the cam gears. Tried starting it quite a few times while it was off timing which leads me to believe that maybe I damaged some valves. Maybe I'm overreacting.
Here's a video of the first start followed by the second start where you can see the headers glowing red in those cylinders.
First - http://www.youtube.com/watch?v=NLZjJ...e_gdata_player
Second - http://www.youtube.com/watch?v=pBILe...e_gdata_player
Old Jan 14, 2012 | 12:35 PM
Default Re: Header Glowing Red after 90 seconds. New k build
Bump. Little help here guys...
Old Jan 14, 2012 | 12:38 PM
SR20S13's Avatar
your prob. running super rich, you need to get it tune ASAP or you will wash out your cylinder walls
Old Jan 14, 2012 | 01:27 PM
It's a basically stock motor with a stock ecu.
Old Jan 14, 2012 | 01:40 PM
DraginX's Avatar
Looks like timing is still off. I don't know a whole lot about the k-series but it definately shouldn't be doing that on just idle.
Old Jan 14, 2012 | 02:25 PM
Just realized I'm using a accord tps that came with the tb that did work for me so I used all the sensors from the accord. I believe it was a accord because the throttle bracket was on the wrong side. Could that be my issue. Because I'm getting no where near .45v and 4.5v on mine now with the tps on the way I think it goes. I do however get a .5v when it's in a position that doesn't like up with the screw holes.
Old Jan 14, 2012 | 03:06 PM
Think I got it. I had the tps and map plugs switched. Would that do it? *Also now that I'm trying to adjust the tps I can only get as low as 1.5v at closed throttle and I'm at 5.10 at wot. *
Think I used an accord tps. Would that matter?
Old Jan 15, 2012 | 07:03 AM
Well I assumed the header heat issues were because I had the TPS and MAP switched. But how come I never got a code for either? And I also never got a code for crank angle which I thought I would if it was out of timing.
Old Jan 16, 2012 | 06:31 AM
kyden's Avatar
because tps and map have the same voltage sweeps, so it wouldn't know the difference between the two.
Akeem Willis
Oct 18, 2017 08:37 PM
nhpreludekid
Oct 24, 2013 01:43 PM
Sp00nFed EM1
K Series
Apr 3, 2012 08:05 PM
Seanz_Ac_Da
Apr 13, 2010 08:54 AM
trulala
Dec 18, 2006 10:16 AM
