Help This 01 Accord Newbie Get on the right track
I recently bought my son a 01 Accord Coupe with 210k miles 4 cyl auto
-Trans is very smooth
-engine is quite and strong
Here is what I have done so I need your help in anything else to do to keep it runnng well and safe for him:
-Took it in for airbag recall and fixed
-Did Trans flush (drain and fill method X3) with Honda atf
-Oil Change
-Coolant Change
-Replace Timing belt and water pump and other belts near by
-new tires
-new wipers
-Replace PSF using turkey baster method (x2) with Honda PSF
-Brake fluid same with turkey baster
-cleaned/sanded headlights
-New plugs, wires, dist cap
What else should I do?????
Thank you!!
-Oil Change
-Coolant Change
-new tires
-new wipers
Thank you!!
compscience007
Aug 16, 2017 01:35 PM
silvercas
16
Dec 20, 2008 05:18 AM
stevescivic
Apr 15, 2008 11:46 AM
