Billet transmission housing
Sorry about that.i need a stronger housing for incresing power.im getting ready to put in after maket gears in but if the housing cant take the beating im not going to invest in n them...im planning on heat treating the casing as a last resort but I rather replace it it if possible.....thanks guys
A company called "Insane Speed" is making some billet housing for EVO's. Not sure if they are involved in the Honda world or not, but you could check them out.
@ http://insanespeed.net/
Good Luck.
Good Luck.
You don't need a billet case. Roger has gone 9.30's on a stock case, the gear sets are the weak link. Keep in mind you'll lose 5th if you go to PPG gears. Not sure what the availability of the gear set is at the moment either.
Thats true.i went to many companys and they dont offer what i need.im going to get some gears imported from australia for a pretty penny and im pribably going to heat the tranny casing because i know that thimg may give out.( heavy car)
The reason the don't offer "what you need" is that you don't need it! As people have stated already, the cases hold up just fine to guys running 7-800+ and low 9 sec 1/4 miles in heavy Prelude and Accord chassis. The gears and synchros let go, so those need to be upgraded, but used in stock housings.
