fs 95 civic hatch
Old Jan 12, 2012 | 10:47 PM
mike11's Avatar
Default fs 95 civic hatch
PINK IN HAND!! i have a clean 95 civic hatch for sale. car has been garage kept since 2008 $4000OBO WILLING TO NEGOTIATE!! BARD FOR B18B1!!
i dont thrash cars so engine is mechanically good, routine oil changes mobil1 extended performance, always use 91 octane, no ps or ac, valves checked every 1000miles. motor has very low miles. if you look inside engine there are no oil stains or gunk anywhere, very clean engine. tranny is same condition but might have more miles because it is usdm tranny, before it was painted the outside looked new. axles are new put them in when motor was swapped into chassis, wiring done right, everything soldered correctly. motor is guranteed to pass smog with stock exhaust setup and new cat. currently non-oped. fees are 336$ to get it registered. willing to take 4000$ because of that.
car ran a 14.00et untuned
body:
spoon mirrors
jdm eg6 fogs
amber corner lights
jdm eg6 fenders
carbon fiber hood very clean
carbon fiber duckbill very clean
suspension:
cusco zero-2e coilovers compatible with cusco econ controller
itr lca's
buddy club p1 lower extended ball joints
passwordjdm spherical bearings in rear trailing arms
wicked tuning spherical rear camber kits
bucknell traction bars
rear strut bar
rear c-piller bar
trunk bar
rear disc conversion.
engine: b16a
250psi all four cylinders
str 68mm throttle body
crower stage 2 cams
supertech dual valve springs
supertech ti retainers
str 5-bolt adjustable cam gears
blox intake manifold port matched
str fuel rail
aem fuel pressure regulater
summit fuel pressure gauge
ported head
stock shortblock
moroso oil pan with moroso oil pickup
type-r underdrive pulley
fidanza 7lb flywheel
excedy stage1 clutch
exhaust gasket port matched
hytech big tube headers with custom 3in flowmaster collecter
spoon oil cap
walbro 255 fuel pump
aem cai
innovative billet mounts polished
gsr tranny.
interior: pretty much gutted
skunk2 short shifter
s2k shift ***
momo steering wheel
momo hub
jdm eg6 cluster
tenzo r bucket
sabelt 6-point harness
modified seat pan.
wheels: 16x7 +35 offset red with polished lip brand new tires. blox extended studs, blox chromoly steel lug nuts. wire tucked.
pics up tomorrow
Old Jan 13, 2012 | 02:57 PM
mike11's Avatar
Default Re: fs 95 civic hatch
bump for pic
Old Jan 13, 2012 | 03:56 PM
mike11's Avatar
make some offers willing to negotiate
Old Jan 13, 2012 | 05:34 PM
mike11's Avatar
the pic has old wheels. need this thing gone a.s.a.p, just took it for drive runs great!
Old Jan 13, 2012 | 05:38 PM
mike11's Avatar
body is clean only has a few dings, has been waxed, really good paint no fade at all. oem frost white never painted
mike11's Avatar
let me know i can send pics from phone
Old Jan 13, 2012 | 05:58 PM
mike11's Avatar
i dont thrash cars so engine is mechanically good, routine oil changes mobil1 extended performance, always use 91 octane, no ps or ac, valves checked every 1000miles. motor has very low miles. if you look inside engine there are no oil stains or gunk anywhere, very clean engine. tranny is same condition but might have more miles because it is usdm tranny, before it was painted the outside it looked new. axles are new put them in when motor was swapped into chassis, wiring done right, everything soldered correctly. motor is guranteed to pass smog with stock exhaust setup and new cat. currently non-oped. fees are 336$ to get it registered. willing to take 4000$ because of that. if theres anything else you need to know give me a call or text number is at top of page
Old Jan 14, 2012 | 07:46 AM
HondaMang's Avatar
is the swap bard ?
Old Jan 15, 2012 | 10:28 PM
mike11's Avatar
Originally Posted by HondaMang
is the swap bard ?
no
Old Jan 15, 2012 | 10:43 PM
dirty19's Avatar
Ridin Dirty in Cali
more pics might help you sell this faster.
Old Jan 16, 2012 | 03:09 PM
mike11's Avatar
bump
Old Jan 17, 2012 | 06:41 PM
RoTb TwEaK's Avatar
In for pics and bump for a fellow eg owner!!
Old Jan 17, 2012 | 07:19 PM
Turtle_FA5's Avatar
bard?
Old Jan 21, 2012 | 04:41 PM
mike11's Avatar
car is bar'd for ls. it now has crower stage 2 cams and supertech dual valve springs with ti retainers. engine has 250psi all cylinders. im getting digital camera monday and will post photos sorry for the delay
Old Jan 21, 2012 | 06:20 PM
CRXB16B's Avatar
bump would like to see the car???
Old Jan 24, 2012 | 01:33 PM
mike11's Avatar
i will have pics posted either tonight or tomorrow
Old Jan 24, 2012 | 05:02 PM
mike11's Avatar
bump for pics
Old Jan 24, 2012 | 07:35 PM
mike11's Avatar
pics posted
Old Jan 24, 2012 | 10:32 PM
JTTeG_X's Avatar
clean *** EG
would also help a lot for info regarding engine and tranny mileage and where it was sourced. tuned? whp?
Old Jan 25, 2012 | 11:43 AM
mike11's Avatar
Originally Posted by JTTeG_X
clean *** EG
will have numbers on saturday. scroll up for info on engine and tranny
Old Jan 26, 2012 | 12:51 PM
mike11's Avatar
bump
Old May 13, 2012 | 08:13 PM
mike11's Avatar
car ran a 14.00et untuned. make offers
Old May 14, 2012 | 05:04 PM
mike11's Avatar
bump
Old May 14, 2012 | 05:31 PM
mike11's Avatar
just put str 68mm throttle body on
Old May 16, 2012 | 12:27 PM
mike11's Avatar
bump willing to trade make offers
