Suspension & Brakes Theory, alignment, spring rates....
Alignment specs... Need opinions
Old Jan 12, 2012 | 10:18 PM
pKjai's Avatar
Default Alignment specs... Need opinions
97 DB7 Integra Sedan
Tokico illuminas + h&r springs
No camber kits.
Just got an alignment. Need some opinions on the camber differences between left and right side. Is it normal? I know lowering a car affects camber, it's not the negative camber i'm worried about, just the cross camber differences.
Also changed out the the pass rear RTA, along with LCA's/compensator arm/etc to see if I could fix some squeaks, but my sheet from before has the same amount of camber.
Old Jan 13, 2012 | 02:39 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: Alignment specs... Need opinions
That difference in camber is pretty normal and not really a big deal. If you've got ancient bushings it's not really a surprise.
Also, if you're lowered on springs or you don't have your coilovers set to account for your weight in the driver's seat, that could play a role too.
Old Jan 13, 2012 | 09:25 PM
seanbev24's Avatar
x2 it's pretty normal. Half a degree of cross camber is considered within the factory specs of most manufacturers. Your car might pull slightly to the right, but I wouldn't worry about it.
TonyRomo
Jul 20, 2009 01:24 PM
mikeycivic
Suspension & Brakes
Mar 31, 2008 04:00 PM
aSDthing
Suspension & Brakes
Nov 27, 2007 06:32 AM
alfaaay
Mar 21, 2003 06:30 PM
mr tl
Sep 7, 2002 09:39 AM
