Aftermarket Header Clear a/c and Ps in 92 Gsr?
Im looking into buying a decent header for my 92 Gsr, Am I going to have any clearance issues with the A/c ? Also I dont want to have to notch my cross member, Thanks
you will be fine if you get an ebay header since it won't grant you more than 3hp but what i would do is get the welds rewelded like i did on mine so there wont be any leaks
If you buy it from an actual seller or store, they should tell you if any modifications are needed to make it fit. But generally you should be good, ive never had any need to modify.
