97 accord transmission help
Auto tranny, For the last month i feel like my tranny is shifting harder, and sometimes when shefting fro 1st to 2nd the rpm jumps to like 3500 then goes. A buddy told my the trans in my year if just like that. Hmm, and just had a fluid change.
Could be the NM sensor on the right side cover may be getting a bit fouled up with ferrous particles and it's not giving correct resolution which would give the jerky feeling.
http://techauto.awardspace.com/transmission.html
^ go through that link, check the simple stuff first. Also check your TPS, if there is a bad spot on the carbon track it will not allow proper shifting either.
alright first thing you want to do is check the transmission fluid. level and color it should be anywhere red but most likely brownish since it might not have been changed in a while. if it is dark brown or black it be better if u not drain or flush the transmission because it will only damage it. you might need an overhaul or rebuild in this case
Well... Idk what fluid is in it.. So i did a drain and fill and put honda atf, but i gotta do it 3 times to get the old out, so i am doing it again saturday with more honda atf. Because i have no idea what was in it before... :/ hopefully it helps.
my 97 accord's tranny just went out a couple weeks ago and i was experiencing similar issues my advice from personal experience sell it before it goes out before you sell id check the sensors like mike mentioned
Well, my car runs super good! And it only has 130.xxx on it, and i dont wanna sell it and go through getting a nother car that isnt ****ed up, let alone rip someone off..
rayccfhk
Oct 29, 2007 07:15 AM
