short'd wiring 93 da
Old Jan 12, 2012 | 05:46 PM
ducsaim's Avatar
Default short'd wiring 93 da
i have a short that makes my right turn signal stay on and my reverse light doesnt work. wat to do??
Old Jan 12, 2012 | 05:55 PM
fcm's Avatar
fcm
Old Fart
Default Re: short'd wiring 93 da
Your reverse lights, [back-up lights] and signal lights are two differant circuits.
Question, what right signal stays on, front, front side marker, rear, gauge cluster indicator or all of them?
Do they blink or just stay on solid?
Are they on all the time or does ign. switch need to be on? 94
Old Jan 12, 2012 | 06:55 PM
ducsaim's Avatar
when i turn on low beam and guage tail light and front stay on but doesnt blink but will blink
Old Jan 12, 2012 | 07:55 PM
Hidenplanvew's Avatar
huh?? Dosent blink, but will blink?
Old Jan 13, 2012 | 05:27 AM
fcm's Avatar
fcm
Old Fart
Say what?94
Old Jan 15, 2012 | 12:14 AM
ducsaim's Avatar
so here is my problem. i needa know how to fix the Reverse light, and my right turn signal stays on but doesnt blink but will blink if i USE the right turn signal. also when i turn on my fan inside, it has light but the fan wont turn on. it doesnt have the light on the buttons like when the fan blows to face, or blow to legs , and/or blow on ur face and legs. how do i fix those??
Old Jan 15, 2012 | 01:14 AM
el crapitan's Avatar
Old Jan 15, 2012 | 08:02 AM
Jeffaj20's Avatar
CONFUSED
Damn am I confused at how you're writing this.
Have you tried a new bulb for the reverse light?
And when you say right turn signal, front or back?
With the CLIMATE CONTROL those lights and connections go bad a lot. The soldering on them is cracking and losing its connection, or the bulbs could've just blown. So you have to pull it out to either re-solder them yourself/have a friend do it, or buy a new one...
Old Jan 15, 2012 | 09:32 PM
ducsaim's Avatar
so the climate gotta fix wiring, the reverse, ill try changing the bulbs, Right turn signal stays on front back and on the cluster
Old Jan 16, 2012 | 06:12 AM
fcm's Avatar
fcm
Old Fart
OK, that is a little clearer.
As mentioned the "lights", [LEDs] on your mode control buttons, [climate controls] will need repairing, [solder connections] .
If none of them work it is a connection problem between the "Dimmer Circuit" and the and the LEDs or the Dimmer Circuit input, [red/black] or the Dimmer Circuit itself is bad.
For the back-up lights, again as mentioned check the bulbs, also check the back-up lights switch on the transmission, [standard] or the A/T gear position switch, [auto], either way it is a yellow/red, [or just yellow] lead for the input, [from fuse 1 - 10A] and a green/black for the output.
For the signal light I will guess it is the ICU that is causing the problem, it is the only place where there is a 12V constant that could come in contact with the signal light wiring, [unless there is a short someplace else] I would unplug the ICU and see if that solves the problem, the ICU is mounter to the back of the under dash fuse box. 94
smoked08
Apr 4, 2012 12:32 PM
JJGL-EF90
Feb 21, 2011 11:37 AM
DEA7H
Sep 30, 2008 10:33 AM
Alvieh_R
Sep 8, 2008 02:25 AM
onesoejourner
13
Apr 20, 2008 09:50 AM
