Best B-series tranny for LS/B20??
Old Oct 8, 2002 | 03:51 PM
V3locity's Avatar
Default Best B-series tranny for LS/B20??
What is the best tranny to get for an LS or B20 swap. I'll get the motor in and then decide if it gets boost or vtec.....or both. Should I just stick with the 90-91 LS tranny or should I try for something else?
Old Oct 8, 2002 | 03:56 PM
JDM88EF9's Avatar
Default Re: Best B-series tranny for LS/B20?? (illdezignzminime)
If your gonna stay all motor then you might want to stick with a GS-R tranny. But if your gonna go turbo then you might wanna consider getting a LS for the longer gears for the turbo. Hope this helps for you!
Old Oct 8, 2002 | 04:06 PM
V3locity's Avatar
Default Re: Best B-series tranny for LS/B20?? (JDM88EF9)
I'm almost positive it will be FI. So the LS would definitely be the best bet? That seems to be the concensus of everything i've read. Now, where can I find one or should I just get a full LS swap and switch to the b20 later???
Old Oct 8, 2002 | 04:08 PM
JDM88EF9's Avatar
The LS tranny would be your best bet for a turbo application and you can find a LS tranny at your local junkyard or somewhere else. Check the classifieds...
Old Oct 8, 2002 | 05:35 PM
StorminMatt's Avatar
The LS transmission would be your best bet. Although the Y80 GSR transmission would also be good, it does not bolt in with typical B-series mount kits. And the YS1 GSR transmission is much too short for freeway driving.
Old Oct 8, 2002 | 05:51 PM
EightOhOne's Avatar
Default Re: Best B-series tranny for LS/B20?? (StorminMatt)
http://www.car-part.com look for your ls tranny there
itz_nij
Mar 15, 2004 05:26 PM
Billy_goat
Sep 21, 2003 01:40 PM
Blaze45
Sep 14, 2002 06:38 AM
Adampops
Feb 5, 2002 09:49 PM
4isbetter
May 3, 2001 05:33 AM
