b18c1 bearing material
Old Oct 8, 2002 | 03:48 PM
Tomakit's Avatar
Default b18c1 bearing material
coming from https://honda-tech.com/zerothread?id=300901
"...(t)o remedy the problem, a team of Honda metallurgists/engineers created a highly seizure-resistant overlayon the bearing's sliding surface using a unique electrodepositing of tetra-methyl lead, Pb (h00). The highly oriented Pb surface has a composition of myriad minuscule pyramids, which possesses outstanding "wettability" or lubricant-retaining properties. Honda claims is has given a 30% or higher increase in the anti-seizure parameter, PV, than a surface with conventional deposits."
The problem was that the max sustainable rpm that the b18c1 could hold was 7500rpm while in development. These new bearings, along with improvements in con rod material technology, allowed a max sustainable rpm of 8100.
Tom
[Modified by Tomakit, 8:38 PM 10/8/2002]
Old Oct 8, 2002 | 04:37 PM
Cow's Avatar
Cow
Default Re: b18c1 bearing material (Tomakit)
Ok.
Old Oct 8, 2002 | 07:56 PM
vteg's Avatar
New User
If gsr's and itr's use the same bearings then that article would need updating
Brembomaster
Engine Machining & Assembly
Jan 18, 2019 11:01 PM
B-series BEAST
Aug 15, 2012 12:14 PM
soon2bdropped
Dec 4, 2008 07:48 PM
christion
Nov 6, 2006 08:25 PM
tgreaves
Feb 2, 2004 01:17 PM
