engine wet...uh oh
Old Jan 12, 2012 | 11:12 AM
JusAccord's Avatar
Default engine wet...uh oh
i know its gonna rain today...i jus putt my engine back in my car real quick, of course the hood is off, i went in the house to get something, came back out and it started light sprinkle rain out, is my enigine gonna be fine once it dryed up, it will start righ? IT BETTER! LoL
Old Jan 12, 2012 | 11:13 AM
Dc4LsTeG's Avatar
EK9
Default Re: engine wet...uh oh
Should be fine if you covered it and it only got a little water sprinkeled on it
Old Jan 12, 2012 | 11:16 AM
JusAccord's Avatar
yea i covered it with the car cover, i hope so man lol
Old Jan 12, 2012 | 12:36 PM
AznBlueBoy's Avatar
If you bring your car to a detailer, they spray your engine down with a pressure washer.
I think you'll be fine.
Although sometimes they get the distributor wet and it wont start.
Old Jan 12, 2012 | 01:02 PM
Wrona's Avatar
you'll be fine i just washed my motor with degreaser and a bucket yesterday all i did was let the water dry off as long as your spark plug wires seal the plugs and you're going to be fine just make sure you take off the fitler if you have a SRI or a CAI to see if any water got into the tube
Old Jan 12, 2012 | 06:38 PM
snobordboy's Avatar
Moderator
Do you think the engine stays dry when you drive in the rain????
And a bit of water on the filter is fine too, you have a problem when the filter can suck in alot of water, and hydrolock the engine. You do want to keep water out of the plug holes and distributor as much as possible though.
Old Jan 12, 2012 | 06:49 PM
NOFX's Avatar
H-T White Ops
The only problem I've ever personally experienced with water and an engine was when my friend went to start her car after we sprayed the engine bay down and it wouldn't start up. Turned out the seal in the distributor cap was bad and it leaked.
I've sprayed down loads of engines wit a pressure washer and never had a problem except for that one (that one I only used a garden hose with even).
Old Jan 14, 2012 | 05:35 PM
JusAccord's Avatar
it was jus the head, block and transmission, nothin else was attach yet, i jus finished the job tho, im goin to start it up tomorrow, wish me luck
Old Jan 15, 2012 | 11:03 AM
DrewsPrelude's Avatar
You should be fine today when you start up...I was swapping out my hood for a lighter hood and before I attached the new hood I drove down the street without my hood and it started to rain. Im still running
hafaadaiteg
Aug 28, 2007 07:21 PM
lakerschamp2000
Oct 1, 2004 04:26 PM
guero2517
25
Apr 2, 2004 12:21 PM
el402
May 19, 2002 04:06 PM
riot
Apr 28, 2002 07:31 PM
