07 and up civic si trans
Old Jan 12, 2012 | 09:49 AM
HONDAPARTSMANMIKE's Avatar
Default 07 and up civic si trans
just wondering if anyone has put an 07 and up civic si trans in a 02 rsx type s if so is there anything required part wise. so far i have the trans and the k tuned adjustable speed converter.
Old Jan 12, 2012 | 09:56 AM
doood's Avatar
been there done that
Default Re: 07 and up civic si trans
http://www.k20a.org/forum/showthread.php?t=40933
Old Jan 12, 2012 | 10:00 AM
thank you but i saw that thread im just wondering if i extend the wiring from the rsx harness long enough to the speed sensor on the si trans would it work.
Old Jan 12, 2012 | 06:37 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
No they are completely different VSS sensors... your 02-04 is a gear driven VSS... The 07si uses the same magnetic VSS the 05-06 RSX uses.
Old Jan 15, 2012 | 01:15 PM
ok so i installed the 06 and civic si trans. all i had to is install the k tuned speedo converter and swap the shifter mechanism off the 02 rsx and put it on the si trans. only 2 bolt holes line up the other 2 i had to drill and tap. it was a very simple trans swap
Old Jan 15, 2012 | 06:26 PM
dstnbmxvr6's Avatar
I also have done this, there is a write up I did when i did mine. I love the ratios and lsd!
Old Jan 16, 2012 | 06:13 AM
i wasnt able to find a write up other the swaping the the speed ring gear in the trans and drill the clutch side case to bolt in the orginal 02 rsx speed sensor. oh well its done now and works great. hopefully when the customer drives it he will like it
k_powered_hatch
Honda Civic (2006 - 2015)
Mar 5, 2012 04:24 PM
evilhatch2.0
May 4, 2010 07:59 PM
gadrian
Sep 28, 2007 05:21 PM
zeroluck
29
Jan 23, 2006 03:15 AM
KOREAN
18
Apr 20, 2005 07:05 PM
