D15b2 with a6 cam
Old Jan 11, 2012 | 08:11 PM
jdm89crxhf's Avatar
Icon2 D15b2 with a6 cam
would i b able to put and properly run a D16a6 cam in my b2?? would i need anyothet mods is it even worth doing?? kus ma friend is running a a6 cm in his d15b7 so just wanted to know if i could do the same!??
Old Jan 11, 2012 | 08:13 PM
KINGVEM^^ED6's Avatar
Default Re: D15b2 with a6 cam
IIRC that's the only difference between the b2 and a6 should work fine brahhh
Old Jan 11, 2012 | 08:21 PM
jdm89crxhf's Avatar
any gain in hp?? n so just slap in the a6 n thats it
Old Jan 11, 2012 | 08:53 PM
Google a6 cam in b2 like I said I'm not 100 % sure but I know its been done
Old Jan 11, 2012 | 08:59 PM
ef yu's Avatar
i tell you know, you wont feel much, if any, difference.
Old Jan 11, 2012 | 09:39 PM
jdm89crxhf's Avatar
yea did the research timming will b off by a half a tooth there for i can use a y7 y8 cam gear or get an ajustable one might do it not shure was just thinking bout it
Old Jan 11, 2012 | 09:51 PM
redef90si's Avatar
not worth it IMO Go MPFI(Multi point fuel injection)
instead,will be more beneficial in the long run.
Old Jan 11, 2012 | 11:19 PM
290allen's Avatar
the a6 cam is literally the exact same lift and duration as a b2 cam. the only difference is the cam gear offset. you will gain nothing from this. the oem manual has all of that info.
Old Jan 12, 2012 | 06:29 AM
24TEN's Avatar
PHANTOM MENACE
You've never seen them side by side then or measured them for yourself. You will definitely feel an increase mainly in the upper RPM range if you swap this in and get it timed a specific way (mechanical and ignition) but just throwing it in with all else stock you'll barely notice any difference (confirming what "ef yu" stated). Having said that, you will NOT have a fast car with this alone. Combined with the MPFI conversion you will have essentially an Si with slightly less torque. So if having an Si with slightly less torque sounds good to you, go for it.
Old Jan 12, 2012 | 07:49 AM
290allen's Avatar
As a matter a fact i have seen them side by side, I have seen the 88-91 d-series cam specs side by side straight out of Honda material. And i have physically used calipers and measured them. Check your facts again.
Old Jan 12, 2012 | 07:55 AM
24TEN's Avatar
PHANTOM MENACE
I'll post up pics later from my camshaft that I swapped vs my original but for now I'll dig around, see if I can find the pics online from someone else. I know I've seen them before or I wouldn't have done the swap because like you, I saw the specs in the FSM and saw that they were the same but the pics online showed otherwise as did my own experience. Give me a while...
Old Jan 12, 2012 | 08:02 AM
290allen's Avatar
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/si-cams-into-d15b2-1595071/
read it for yourself.
Old Jan 12, 2012 | 08:46 AM
24TEN's Avatar
PHANTOM MENACE
I actually found my mistake before reading that, my DX camshaft is out of the newer 92-95 Civic. Carry on...
EDIT: I'm still finding conflicting info, might be worth a trip to the junkyard to get one for myself and measure lobe heights, base circles, lift, and duration.
Old Jan 12, 2012 | 09:09 AM
290allen's Avatar
like i said i have measured them both one after the other. They are exactly the same with the exception of the d15b2 auto as mentioned in the link i previously posted.
Old Jan 12, 2012 | 09:47 AM
24TEN's Avatar
PHANTOM MENACE
That link doesn't verify duration which is where I'm finding conflicting info. Don't worry about it though.
Old Jan 12, 2012 | 10:46 AM
290allen's Avatar
i wont... but if you take some measurements post up your result if you find something different.
Old Jan 12, 2012 | 08:55 PM
vtec4thgen's Avatar
I did this in my 93 4 door runabout. It works and will add a little throttle response but that about it
Old Apr 14, 2020 | 06:24 AM
David Hudgens's Avatar
where do you find the a6 cam because i have an 89 crx with the d15b2 and its a little sluggish even with the mpfi swap and pm6 ecu and i read that the a6 cam with y8 cam gear should make this engine a little more fun and idk if this would have anything to do with it bit ots the mpfi from the hf but could anyone link where I can find and buy the a6 camshaft
Old Apr 14, 2020 | 04:06 PM
Efmysedan's Avatar
what state?
I have the head taking up space
Old Apr 15, 2020 | 08:00 AM
Originally Posted by Efmysedan
what state?
texas and how would i buy it
Old Apr 15, 2020 | 05:20 PM
Efmysedan's Avatar
I’ll take it out of the head and take it to the post office with your address
do you really want it?
kyle2436
Jun 16, 2008 09:06 AM
Coolcat55
Apr 3, 2007 04:33 AM
madcrossover
Nov 1, 2006 06:52 AM
ABK
Oct 12, 2005 08:57 AM
