Another Idle Issue thread
I have searched high and low for answers but haven't seen anything that seems to be the identical issue I'm having. The car is a 99 hatch with a b16a2 swap running on the OEM ECU. Car has run flawlessly for the last year and a half. All of a sudden I have a terrible idle. It fluctuates badly up to 3K. It drives perfect as long as your above 3K rpm. vtec works just like it always has.
Its sucking air from lower hole in the TB at idle/off throttle whether its below or above operating temps and its audible inside and outside the car. When I plug the lower hole the idle drops but doesn't act like it wants to stall. Is the lower hole the IACV and the upper is TPS? Car has no FITV. While driving at about 3500 in 5th gear I can slightly roll into the throttle and the audible sucking from the intake goes away immediately with next to zero load on the car (No bucking or surging).
Heres a couple vids to show what its doing. First one is of the car up to temp with the iacv unplugged.
http://s82.photobucket.com/albums/j2...t=73b93b9c.mp4
Here is what it does on a daily basis with IACV plugged in whether its cold or up to temp.
http://s82.photobucket.com/albums/j2...t=c10a7f13.mp4
This is what I have done so far.
Checked for VAC leaks with Carb Cleaner
Seafoamed it
Pulled the plugs and they are great, wires appear fine
Bled coolant
Pulled intake pipe and its sucking air hard from the lower hole in the Throttle body. Plug the hole and the idle is steady where it should be.
First I cleaned the old IACV then I Swapped out the IACV with a new one
Reset ECU (A couple times, after the new IACV as well)
The only other recent work done on the car was a new alternator belt as it was slipping. This problem starter about a week later which also was the point when the weather dropped consistently below 40.
Thank you very much for any help you can offer!
Seafoamed it
Bled coolant
If the ECT sensor resistance is fine, then you would next test output voltages from the TPS and follow the service manual procedure for adjusting the idle speed (see section 5L in FAQs sticky).
Reset the ECU (pull 7.5A hood Back Up fuse for 3 or more minutes) and then see whether either of those codes returns after driving.
I'll have to check it tomorrow as its getting late now. Whats weird is that the car has run flawlessly for the last two years. I'm not sure on the two sensors being hooked up, I'll have to look tomorrow.
Not sure as I had to pull the cluster last night because I had a suspicion that the previous owner removed it. Sure enough it was removed. I moved the ebay light over temporarily to get the codes. Still haven't driven it with the light in place so I'll report back on that also.
How did you reset the ECU?
Did you bleed the cooling system after replacing the ECT?
Does the heater element power wire of the primary O2 sensor have battery voltage with the key in ON(II)? What is the resistance of the heater element? If you unplug the O2 sensor, does the idle speed settle down?
Test the KS sensor wire for an open or short. If the wire is fine, replace the KS sensor. If you unplug the KS sensor, does the idle speed settle down?
Just in case anyone is looking in the future. It turned out to be a completely broken off FITV..... Even though it was bypassed it was creating a vacuum. Car runs perfect now.
sik_sol
Aug 18, 2006 02:08 PM
